Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
Posted on Jul 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Date not showing up on my pictures
How do a make the date appear on my pictures?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Canon Master 102,366 Answers
  • Posted on Nov 09, 2012
Canon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428848
Points
622693
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
5 Related Answers
Anonymous
  • 203 Answers
  • Posted on Jun 09, 2008
SOURCE: need help
go to function and change pic size to wide or it shows a w -then you will see in main menu highlight of time and date stamp-canon can only do date and/or time in a certain size pic-rember it's a lower quality resolution than normal-change pic size first at bottom of function menu then go to main menu
arclight1217
BRIAN REISS
  • 208 Answers
  • Posted on Nov 13, 2008
SOURCE: Setting date and time on the picture
OK, I FOUND SOME INFO ON A WEBSITE THAT I'M GOING TO HOTLINK FOR YOU. SEEMS LIKE THE ONLY WAY YOU CAN DATE/TIME STAMP A PHOTO IS TO HAVE THE CAMERA IN THE POSTCARD MODE. YOU CAN READ ABOUT THIS IN THE WEBSITE I'VE LINKED FOR YOU. HOPE THIS SOLVES YOUR QUESTION, AND IF YOU NEED MORE HELP, REPLY TO:ARCLIGHT1217. IF THIS HELPS, PLEASE REMEMBER TO RATE THIS SOLUTION. THANKS!
http://www.imaging-resource.com/PRODS/SD750/SD750A3.HTM
GOOD LUCK!
t00nz
CameraR
  • 4738 Answers
  • Posted on Jun 23, 2009
SOURCE: how do I set camera to print date on each picture I take?
This will only work in postcard resolution. See pages 35 and 36 of the user manual at this link.
  • 102366 Answers
  • Posted on Jul 09, 2010
SOURCE: date appearing on my images, how do I remove it?
Press FUNC/SET, then use up/down to select L. Select the mountain with the clock in front of it. Press left/right to select L.
For full details, see the section "Inserting the Date and Time" in the manual.
Anonymous
  • 178 Answers
  • Posted on Jul 25, 2010
SOURCE: can't get date/time to not appear on screen or download to comp
Are you sure your canon battery pack is OK?If not ,replace it with a high quality replacement battery pack.
2helpful
How do I get the dat stamp to appear
The date and time (and a lot more) are stored with every picture in its metadata. Just about any photo viewing program can show you this data.
If you want the date printed, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer, you may print the date on the image, in the margins, or on the back.
2answers
My camera shows that the date and time are set up but date does not print on picture when developed. it's a new camera and I just developed my first set of prints and there is no date on any of them. ...
On digital cameras, the data is stored with the filename. Check the back of your prints to see if the dates were not printed there. Most companies do put at least the date information on the back of the prints as well as any other metadata stored with the file produced by the digital camera. Unlike film cameras, which could only record the date by actually putting it on the picture, digital pictures contain metadata that can include things such as people tags, location tags (geotagging), etc. depending upon the capabilities of your camera. The date and time is always stored along with the filename on all digital cameras. If the company that printed your pictures did not include the date on the back of the picture, ask them if they can do it or find another source to print your pictures that can.
If this did not address your issue, please reply with any amplifying information so that I may more accurately address your issue.
I hope this helped!
2answers
I wanted to know how do i get the time/date on my pictures when i upload them on to the computer
The time and date (and a lot more) are stored with every picture when taken, and the data remain with the picture when transferred. Just about any photo viewer should be able to show you the so-called "EXIF" data. For example, in Windows Explorer if you simply hover the mouse over a picture it will show the date/time it was taken.
If you want the date stamp to appear when you print, please refer to the documentation for whatever program you're using to print. Depending on the program and printer, you may print the date on the image, in the margins, or on the back.
Can't get the date to show on the picture... i set the date but can't get it to appear on the actual picture...
The date and time (and a lot more) are automatically stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
How do I get the date and time to show up on either printed pictures or on my downloads onto my home computer? I have set the date and time but it doesn't show up on anything, even my cameras own screen.
The date and time plus a lot more information is stored with each picture as "metadata". It can be retrieved in most photo editing programs. After downloading to your computer, if you just right-click on a picture file, the date and time will appear.
2answers
Windows Explorer will not display Date Picture Taken
When you saved the pictures in My Pictures it will only show the date modified.
A560 cannon camera, I want the date to appear while printing.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
