Coffee Makers & Espresso Machines Logo
M
MHart Posted on Dec 02, 2016
My cappucinatore no longer draws the milk into it. Secondly, the machine leaks dirty water.
My nescafe dolce gusto mini me is leaking milk from the bottom so some milk is going into the cup and the rest on the worktop. Any ideas?
If your Nescafe Dolce Gusto Mini Me is leaking milk from the bottom, there may be a few possible causes:
  1. Check the milk capsule: Make sure that the milk capsule is inserted properly and is not damaged. If the capsule is damaged, it may cause leakage.
  2. Check the milk frother: If the milk frother is clogged or not working properly, it may cause the milk to leak from the bottom. Try cleaning the frother and see if the problem persists.
  3. Check the machine: Check the machine for any cracks or damages that may cause the milk to leak. Also, make sure that the water tank and drip tray are properly in place.
  4. Contact customer support: If none of the above solutions work, contact the Nescafe Dolce Gusto customer support for assistance.
In any case, make sure to clean up any spilled milk thoroughly to avoid any safety hazards.
I have a nespresso Latissima with auto milk frothier & the plastic tube which draws the milk tastes & smells like curdled milk. I can taste it in the coffee as well.
Try running 1/5th vinegar and 4/5 water through the frothing device. This will clean out any gunk that might have clogged the interior
My jura X7 system is rinsing with milk. When pressing the rinse button, the machine is drawing milk to rinse instead of water??
The milk tubes should be submersed into water with a milk cleaning agent. sounds like you've left the milk tubes drawing from the fridge with milk in it.
Bean to cup cleaning
4helpful
3answers
Delonghi Lattissima EN 660CW milk frother not frothing
I don't know why my answer posted in the comments section, so here it is in the proper area.
I had the same problem and was ready to send it in for repairs, but I talked to a great guy at Nespresso who helped me fix it myself. The problem was when I pushed the latte button, it would only froth milk for a second or two and then the espresso would start pouring. It basically refused to make a latte. Here's the things he had me do:
1) Descale immediately. I have an older machine, and descaling once a year does NOT cut it. He told me descaling every 5 months at the bare minimum, if your machine is not having any problems at all. Descaling is usually the main problem for lack of froth. I descaled and it seemed like the machine was working better almost immediately. I also ran 4 - 5 tanks of water through the hot water spout and the main espresso part (but mostly this is because it seems to take this much flushing to get the smell of the descaling solution out).
2) Reset your machine to factory settings. I have a classic Lattissima, so this is how you do it on that machine. Turn the machine on and wait until the drink buttons are steady (espresso and hot water buttons are no longer blinking to warm up). Then press and HOLD the power button until the espresso and hot water buttons BLINK THREE TIMES. Then they'll go back to steady again. You're now back to factory settings.
I did notice that I started having the trouble after moving the machine, so I'm not sure which of the above solved the problem. The main thing is it worked and I'm back to yummy lattes!
2helpful
2answers
Cappucinatore won't pull milk through the tube
Hi
There should be a small pin on the top of the Cappuccinator. When it starts, twist the pin slowly until the milk flows up the tube. Then leave it where it is and it will work all the time.
9helpful
2answers
I have a Delonghi Magnifica Rialto EAM4500 coffee maker. Recently it has stopped frothing milk. Per delonghi I have replaced all of the gaskets that connect between the milk container and the unit. When we...
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
1helpful
2answers
Machine wont draw any milk through
You are not supposed to put milk in the resevoir and run it through the machine. That's likely the problem. But like most parents you will continue to blame your child until he is totally alienated and your relationshio is an empty shell.
Milk island seems to leak water. After milk is frothed and island has been detached fro some time, a pool of water forms under the base of the milk island attachment and on top of it.
Milk island on a vienna class?
Perhaps its a Saeco Talea you have, correct?
First remember that after foaming your milk and have turned the knob back to´off location. wait until you hear a clicking sound from the machine, might take 2 -5 seconds after it set to off.
Then remove the milk container
That sound means it has close 100% and shouldent leak.
If it still leaks after that its the gaskets in the T-pipe that needs to be changed.
2answers
Miele 2660 Steam Problem
ok " take a small steel wire run it back and forth threw the tube
will clear it .
Capucinatore problem?
Try programming the cappucinatore button. First try holding it down for about 20 seconds while steaming. See if it will steam for 20 seconds after that without holding the button down.
Saeco Parts and Cleaning supplies
www.cerinicoffee.com
Top Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
