CE 250 FAQs SINGER Futura Support ..this link might help you out
SOURCE: Singer Futura CE 150 not recognizing small hoop
Except advices from the previous posts I suggest to check out whether you install small hoop precisely, there should not be any deflections, you need to insert it on the full length and fix it very well.
SOURCE: futura ce-100 embroidering in the wrong place
I decided to simply start from the beginning and start all over. I turned off the machine, detached the embroidery unit and blew into the sensor (where the machine and embroidery unit connect). I'm not sure what the problem was, but it was fine after that! Just goes to show that no matter how frustrating things can be, it pays to just take a moment and start over!!
SOURCE: I have a Singer Futura CE-250 and when I am
Try Gezina Sewing machine I find they are very helpfull.
(012) 335 0636
SOURCE: Hi, I'm trying to embroider
The plastic drop-in bobbin case, is the worst I have ever seen. The thread will get jammed in it or it hops while the machine is sewing. It is not staying in place. In front of the case, on the right there is a tiny, rectangle spring. It is the only thing I can find that keeps it in place. It is attached with a tiny screw and can be moved forward.
SOURCE: What part(s) would I need to embroider baseball
It depends where do you want the embroidery to be.
If is on the front part of the cap there are two ways:
One is with sticky stabilize rmaking sure all the parts of the cap are laying flat on the sticky paper.
The second way is with a special cap attachment (sells for around 440) that comes also for the singer futura.
Your top thread could be broken or about to break; your bobbin thread could be broken, about to break or empty/about to become empty and is loose around the bobbin; you could have a birds' nest (a mass of thread just under the fabric/presser foot and/or within the feed dog and bobbin) forming and causing a jam; or it could be your Futura having a little bit of a hissy fit. Obviously, if you've checked for broken thread you need to move on. Check for a birds' nest by removing the fabric and clip your threads. If you find one, clear it, rethread your bobbin and begin sewing again. If there's no birds' nest, then place the fabric back in and try sewing/embroidering again. If the machine acts up again, I recommend removing the fabric/hoop, rethreading your top and bobbin threads, replacing fabric/hoop and resuming where you left off. If the machine still gives you trouble, try hitting the start button for a couple of times and seeing if the problem doesn't simply resolve itself. When you're embroidering areas that have a few small, short stitches only, the machine seems to act up a little and then behaves fine once you bypass the area. Be sure to take all of the other steps first, though, because a birds' nest will RUIN a beautiful seam or embroidery.
