click on the settings icon and go to notification
if it has there will be ring tone , ring and vibration, vibration, silent
if there is no vibration word then it will not have
you can turn your volume down which will then only work the vibrate motor or in settings go to "sound" change sound mode to either mute or vibrate instead of sound. you can set vibration intensity to low for notifications. also under "ring and notifications" change your notification tone silent at the top of the list.
This has nothing to do with the game, but with the tablet. This a very resource intensive game, and if your tablet does not have a fast enough processor or ram, it will keep freezing.
Go into the settings for the Bauhn tablet and reset the sound volumes. This also happens when you plug in the HDMI. Otherwise you can back up your files, then flash with a custom ROM to the tablet to get your sound back again. Updates to the ROM should correct the scratchy sound and stop the silent mode problem.
Possible there is software or a hardware issue on the phone. To start with remove off the battery and keep aside for about 30 minutes.Put back the battey and restore the phone to factory settings by using the restore key and the default code of your phone.
If the phone is now set to mute the ring and vibration and if this works we have achieved the goal.
But if the fault remains, it can be a fault of the vibrating motor shorting without a control
The last resort is to reinstall the software to clear any errors in the software.
Helpful?
i figured out how. on the volume buttons (on the side) you just keep pressing the down button even after it says vibrate., if you press it enough (consecutively) it will say silent all
hope that helped
To place the handset in Silent / Vibrate Mode Step 1 To place the handset in Silent / Vibrate Only Mode, hold down the pound key (#) for about 2 seconds. To exit Silent / Vibrate Mode, perform the same action while in Silent / Vibrate Only Mode. You will see a confirmation message for Silent / Vibrate Only Mode, each time you enter or exit Silent / Vibrate Mode. The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent Vibrate Only Mode. Step 2 While in standby mode, press the volume key, located on the left side of the handset, then select either “Vibrate Only", “Alarm Only” or “All Sounds Off”. To disable perform the same action while in Silent / Vibrate Mode. The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent / Vibrate Only Mode.
