Computers & Internet Logo
Posted on Jul 20, 2009
Error 0XC000000C and 0XD000001E and 0XA0000001 how would I fix these errors its on a Aspire 5315-2153 Notebook did have Window Vista as OS I tryed the backup disc I made 1-9 error OXC000000C on disc 7 I have the Recovery Disc Set SYS DISC Recovery Disc 1 & 2 on disk 1 I get this error OXD000001E Boot Manager menu has this 1:IDE 0 Hitachi - 80.0 GB 2:IDE 1:Optiarc CD-RW Atapi 3: Network Boot: MBA V10.0.9 Slot 0500 I get windows is loading files then it asked what language English then next screen load recovery disc # 1 then restore to factory Default screen then next is Restore Partition Destination screen harddisk0 partition2 no current process 0% at all the other spaces are empty on this screen thats when the error comes up Restore Failed Reason 0XC000000C when I use the backup disc I get windows is loading files then the next screen saids to put disk 2 then the language screen then next disc the factory restore screen then ShowPageConfirm error can'nt find images*.WSI next screen DecompressEngineWasay has Illegal command line arguments and INI file then next screen error restore failed- reason 0XA0000001 if i use the system Disc they sent with my backup disc error 0XA0000001 happens thank you all that try to help
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Sep 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
35075
Points
8
My 0xc000000c "Restore Failed" prompt seemed to be the result of disk surface damage on the restore disk. After burning the restore disk to a new disk, the restore proceeded normally. Try making a copy of the original restore disk to a known good blank disk.
  • Anonymous Sep 26, 2010
    Note: My recovery disks were for an Acer Aspire 5100 laptop.
0xa0000001 stop code
Have a read of this: http://www.tomshardware.com/forum/392938-33-0xa0000001-bsod-code-caused-atikmdag-sapphire-7970
and this:
http://www.tomshardware.com/answers/id-1690717/bsod-0xa0000001-error.html#.
If this laptop is still under warrantee, I'd get it replaced. You could spend hours/days tracking down the cause of this. You could spend hours/days updating faulty drivers, running diagnostic tests such as Memtest, HDTune. You may even fix it - however what's to say the problem doesn't re-occur somewhere later in life.
That's why we have warrantees. I'd use it if you can.
H
2answers
I turn on laptop and i get message saying windows couldnt start and to either select start normally or to load windows repair manager i did this but it couldnt fix it.so i tried using alt F10 for restoring...
It looks your Win OS has become corrupt....
If you have a install Windows disk...
then insert that in the CD drive and start the PC
when the system boots from the disk and Win loads
chose the option repair my Windows....
then follow on screen ins
if that does not help...i am afraid you may have to re-install the Win OS....
for full details visit my website...(has all required details and links to tools for re-installing Windows)
www.sureshayyar.110mb.com
all the best
let me know if that helped...
WHEN INSTALLING ACER RECOVERY DISC I GET ERROR CDE 0XD000001E
0x1E means KMODE_EXCEPTION_NOT_HANDLED
See this link http://www.aumha.org/a/stop.php
Which is often the case that the program is not coded properly for error handling.
hope this link will really helpful to u....
Tried to recover with erecovery disk ran to 100% and then said restore failed and gave error code 0xd000001e
Go online, and type in the error code at google.com, that should steer you in the right direction.
O/S Vista I have the recovery disks and backup error
The restore distk u have have curroupted...... Please try to order new recover disks so that u can install the OS with out any issues............ Further quries please do let me know.... Take care BYE
0xd000001e and subsequent black screen
The easiest way is to hit F10 right after the Acer splash screen. This will take you into recovery mode on the laptop. Then just do the Reset to Factory Default. This will put everything back to the way it was when you purchase the laptop. It does this from the recovery partition.
Grand Canyon Tech
Grand Canyon Tech
