SOURCE: Manual shifter wont go into gear after start up
try to start the car in gear make shour that thear is nothing in the whay just in case, if it moves with clutch in then it is the clutch most likley the clutch plate. you can git the part from most parts stors. if you a not mecanicly inclined bring to a garog. replacing this part can be quite dificolt if you dont know what you are doing
SOURCE: How do I manually operate 2003 bmw power windows
hello there
There is no manual overide. You need to press against the glass from the inside and the outside and push it up whilst getting someone to operate the button. This will get the window up.
Hope this helps and please don't forget to rate me.
Many Thanks
SOURCE: 2007 530xi Sports Wagon: where is battery located on 2007 bmw 530 xi...
If it's not under the hood, then the only other place BMW places their batteries is in the trunk. Since it's a Sport Wagon, pull up where the rear spare would be and it will be there, usually on the right hand side.
Hope this Helps,
~00 Buck~
"Still living on the Right Side of Dirt..."
