SOURCE: how to adjust carb. settings on a McCulloch Pro Mac 610 chain saw
turn both jets in untill snug (don't force) turn out ccw one full turn. increase by 1/8 turns untill set proper. should be between 1 1/4 and 1 1/2 normally. good luck. be safe.
SOURCE: need owners maual for mcculloch power mac 6 chain saw
try my answer to the post on McCulloch pro/mac 10-10 chainsaw owners manual... posted by denniswick on Oct 03, 2008
SOURCE: need to replace gas line inside mcculloch chain
You need to disassemble the case to get to the fuel tank. Pull out the plug fitting and replace the internals with new factory grade parts.
SOURCE: mcculloch 3516 chain saw, does not always start.
It must have spark, fuel and compression to run. Your task is to figure out which is missing.
Sometimes electrical components quit operating once beyond a certain temperature. Does it always start cold and become tempermental when warm?
IMO most hard start problems on a chainsaw with a good fuel delivery system are flooded.
Start Procedure
Cold:
Warm:
The 3516 is a MTD McCulloch (Chinese). These saws are in a class by themselves. Good Luck
Lou
SOURCE: I have a husqvarna 435 chain saw and need to
There is a special tool required, the part no is 530035560 available from Husqvarna/Jonsered dealers, as posted earlier this should be a dealer adjustment as the machine is new.
Has anyone sampled the various product mentioned here, and can they tell which one is the best?https://onlychainsaw.com/best-circular-s...
