Question about Sony KV-40XBR700 40" TV
KV-40XBR700, won't come on, standby light blinks 7 times.
    New Friend:
My Sony standby blinks 7 times. Early on the unit wouldn't turn on until I pressed the power twice. now the unit doesn'tcome on at all.it just makes a couple of clicks and then the standby light blinks. TV repair guy said he has seen it before and that it is an intermittent short in the tube -- oh well. I guess I have an excuse to get a new 40" LCD HSTV ;-)
Posted on Jul 22, 2010
    New Friend:
Sony KV40XBR700 tv no picture but sound is on, standby light blinks 6 times
Posted on Jun 29, 2010
6ya staff
SOURCE:
Sony kv-40xbr800 stand by light flashing no picture
How many times do this standby light flashes? These flashes are fault indication, called blinking codes. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the number of flashes. If you wish to get more detail about these blinking codes to Sony TVs, check the site linked here. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 05, 2013 | Sony KV-40XBR700 40" TV
KV-36XBR400 won't turn on, "standby/stero" light
You are correct. You are right about the power supply and replacing with led hdtv. You will be happy with a Samsung led. Time to upgrade.
Mar 04, 2011 | Sony KV-36XBR400 36" TV
My standby light blinks 7 times ?
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Feb 25, 2011 | Sony KV-40XBR700 40" TV
My KV-36HS500 doesn't turn on.
You will need 2 MCZ3001D or MCZ3001DBs and two 18 pin IC sockets. the chips are on the d-board inside the tv.
Aug 13, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
KV-40XBR700 turns itself off, standby blinks 5 times continuously
http://esupport.sony.com/US/perl/model-home.pl?mdl=KV40XBR700&LOC=3 Ok this isn't the best answer in the world but from here you can find a service tech in your area that works on Sony products. Good luck!!!
Nov 19, 2008 | Sony KV-32V40 32" TV
Sony kv-30xbr910 my tv won't turn on and the standby fashes 7 times
Good day.
Your unit has issues with the high voltage section. Particularly the vertical and horizontal sections. Blinking lights indicates that your flyback is not osscilating to distribute the supply to the sections. Please have it checked by a repaiman.
chris
Mar 21, 2008 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
Sony kv-40xbr800
Exact same problem. KV-40XBR800 wont turn on, blinks six times. I am in the process of changing both Ic's part# MCZ3001D with part# MCZ3001DB. Ordered them frm ebay and waiting for the new parts to arrive.
here are the pictures of both chips and after i removed them from the d board.
As soon as i receive the new ones i will put them in. I can't wait to see what happens and i wanted to say thanks to all of you out there for putting this thing up. Thank you very much.
Nov 05, 2007 | Sony KV-40XBR700 40" TV
40XBR700 picture problem.
the problem is loose contact on the pc board try to resold the cold part of the tv
Sep 28, 2007 | Sony KV-40XBR700 40" TV
Sony KV-40XBR700 40" TV Logo
1,036 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
