SOURCE: Removing Old Built-In Microwave
You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
First make sure the Power Cord is UN-PLUGGED from the wall.
1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
GOOD LUCK!!
SOURCE: Kitchenaid KBMC147HSS0 Bulb replacement
If it's the one that lights the cooktop, it's normally beneath the bottom cover.
In some cases, it's located in a compartment behind the grille that goes across the top of the unit.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It may help. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Please let me know if that helps or not.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Broken vent grille for a Whirlpool microwave hood combination
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.
At
our Web site, we have a video
available showing how to remove a typical
grille in seconds.
We're
happy to help you with free advice and we'd appreciate your
SOURCE: No vent for over the range microwave.
Have you selected a microwave yet?
many over the range types can be vented inside if a charcoal filter is used, which you must replace about every six months.
Otherwise, you will need to install a vent system in the kirtchen.
