SOURCE: Lap top will not boot correctly when not connected to ext hard dr
First u check the laptop Display
if it has display, thn it might be problem ur windows
instead of it.
if computer does not give display thn u check the power adopter of ur laptop.
after all gonig through these steps.even u find all these above steps perfect.
it will mean,
it might be problem of ur hardware.
lets check out it by ur computer vendor.
Thanks
Danish khan
SOURCE: My laptop HP zd8000 doesn't recognize Seagate external hard drive
hi..the reason for your problem is your extenal
hard drive has been affected by viruses.The best
solution to this problem is scanning your hard drive.
once you scan it u will be free of viruses and your
laptop will be able to recognise your hard drive.
try it out..
thank u..
rate me..
Check the drive letter assignment for the disks, and make sure it is not the C: driver.
I am assuming you can boot and then plug the disk, right?
So use the Disk Manager to check the driver letter, and change it if it is conflicting with another disk.
Jules
SOURCE: i just taken out my seagate hard drive from pc,
You Should buy Converter IDE to USB connector.
Hi Michael Barnes, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Have you tried connecting it to other computers?
