Question about Leisure Heating & Cooling
My leisure Dwlt65 will not heat up - Leisure Heating & Cooling
2 Suggested Answers
SOURCE:
ercupa190
  • 12223 Answers
SOURCE: my leisure dwlt65 dishwasher keeps switching its self off when going till wash
see this causes and fix it. God bless you
Touchpad and Control Panel If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been have ruled out, the main control board might need to be replaced.
Posted on Sep 29, 2012
Why won't my Leisure CM10FRK range fan oven heat up?
heating element might have burnt thru and needs replaced .
Aug 29, 2016 | Leisure Kitchen Ranges
The power button is crackling when i turn my Leisure DWLT65 dishwasher on. is it the power switch?
Hello. Here is the link to the power button for your unit. Most likely, the contacts inside the switch have worn out causing arcing--hence the crackling sound you heard. I would not use the washer until you get the switch repaired! If the internal contacts are not touching properly, heat will be generated and could cause the switch to melt, thereby creating a real safety hazard(I've seen this happen). Leisure DWLT65 On Off Power Switch I hope I helped you!
Feb 23, 2015 | Leisure Dishwashers
Not emping water
This is a generalize answer, but remove the bottom kick panel to manually rotate the pump motor. In general they can get locked up by objects. Locking up the pump.
May 26, 2014 | Leisure DWLT65 Dishwasher
Dishwasher will not start after being switched on- can you help
Here is the link to the power button for your dishwasher: http://www.amazon.co.uk/Leisure-DWLT65-Off-Power-Switch/dp/B00O470CVM. I hope this helps you!
Jan 03, 2014 | Leisure DWLT65 Dishwasher
Garden leisure spa
check to make sure you are getting 220 to it if not the check breacker
Sep 07, 2013 | Pool & Spa
My leisure dwlt65 dishwasher keeps switching its self off when going till wash
Sep 28, 2012 | Leisure DWLT65 Dishwasher
Leisure levc66x - bang from fan oven blew tripswitch - fan operating but no heat - top oven ok - 18 month old unit
It appears that the ring element for the oven has burnt out and will need replacing.
Hope this helped.
May 13, 2010 | Ovens
Heating & Cooling Logo
Top Leisure Heating & Cooling Experts
Paul Carew
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
