SOURCE: Sony KP-51HW40 No Picture, only sound
how many thimes does the light blink, it's an indication as to where you should start looking for the cause of the problem
SOURCE: sony tv red flashes
LED flashes of 8 times are indicative of a "High Voltage Error" which means something along the lines of "T8005 is faulty. (D board)" according to the service manual. Most likely it will need a professional to look at it. A link to the service manual is here: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
SOURCE: sony kp-51hw40
Yes you have bad green and red crt but with an adjustment you can still use it. remove the front panel and you'll see the focus pack (it;s a black piece with 6 rotating knobs on it. Adjust clock otherwise the red and green screen (the bottom line knobs) till the lines has gone. The better way to check it is to adujt in video input with no signal, just black screen.
SOURCE: Remote Code for Universal Remote to Operate Sony KP-51HW40?
Go to Tivo>Settings>Remote Control> Sony.
SOURCE: troubleshoot-5 blinks red light front of TV
TURN TIMER OFF. GO TO SONY.COM, TROUBLESHOOTING, OR
The STANDBY light is flashing on the television and there is no picture or sound.
Solution
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
