Sharp AL-1655CS Laser Printer Logo
l
leon laudie Posted on Nov 29, 2016
If i plug the sharp al-1655cs into my computer will it read it with out having the cd for it
5 Related Answers
Brianzfun
  • Posted on May 07, 2008
SOURCE: Sharp AL-1655CS ERROR MESSAGE
The [H4-00] system error popped up when the power went out of the house. I called Sharp Tech Support (1-630-378-3590) and was talking to their Tech Support in less than a minute.
The FIX? Just press the following keystrokes:
# * C * (That's pound, star, C, star) This will clear the display error, now press…14, then press the green button twice. This should let your printer start to warm up and you have fixed your problem.
Anonymous
  • 297 Answers
  • Posted on Jun 19, 2009
SOURCE: My Sharp Al-1655CS Display is frozen
Thank you!
Sabharish
Anonymous
  • 541 Answers
  • Posted on Dec 30, 2009
SOURCE: Makes noise and will not copy
Check the scan head lock. It can easily be locked or unlocked. It is used to protect the moving parts inside the machine when it is moved/transported. Someone in our office was just making copies and ttapping their fingers on it and they locked it without even realizing it. it is under the top of the machine where the paper comes out. sometimes they are a slide or turn knob.
Anonymous
  • 224 Answers
  • Posted on Apr 09, 2010
SOURCE: need driver - software cannot find disk for Sharp
http://www.sharpelectronics.info/Software.aspx
Robert Kitaji
  • 1335 Answers
  • Posted on Apr 15, 2010
SOURCE: I can not install driver printer sharp al-1655cs
Try the driver at
http://www.massdrivers.com/dir/249878.html
for your Windows 7 system.
Where can i get the drivers for a sharp al-1655cs laser printer for free i have tried googkle i have called sharp and have had no luck
http://sharp-al-1655cs.soft32.com/ ..try this link.just like you i have look around the internet but found nothing for your model apart from this.were it is saying ( SHARP AL-1655CS 1.0.0.17) just below that its saying download.now i am not sure if this is going to give you the drivers but have a look.
1helpful
I have sharp AL-1655CS i plug it in and get
Hello sir; You do need a reset procedure as follow; press "#", "*", "clear" " *" then enter 14 press print.
I need the scanner/copier part of the driver CD - Sharp AL-1655cs
I'm not sure where you downloaded the printer driver but the Sharp website has a download link to the printer and scanner driver according to their website.
http://www.sharpusa.com/products/TypeSoftware/0,1086,20,00.html
Tenho uma sharp AL-1655CS que diz ERRO SISTEMA [H4-00] Auguem sabe me dizer como resouver???
Dear Sir
h4 signal is copier fuser unite problem
such as thermostator or heater lamp is broken or burning
System error L1-00 Sharp AL 1655cs
hi maryanne,delete all the sharp AL 1655cs programme and reinstall the printer software (INSTALL PRINTER) if need more help please log on to sharp copier web site for the manual instruction..before that make sure your printer is compatible for your PC.
3helpful
Sharp AL-1655CS Laser Printer stays in download Mode
you can´t. the only way to fix that is replace to main pwb. i have 3 whit the same problem.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
