Crafts & Hobbies Logo
Irene Posted on Nov 29, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have the wonderland express train won't go around can it be fixed
jhnolson
Level 3:
  • Master 822 Answers
  • Posted on Nov 29, 2016
jhnolson
Master
Level 3:
Answers
822
Questions
Helped
292961
Points
5434
Yes, but before I took the set to a model train dealer I would check the basics. Depending how the unit is stored I would assume that corrosion(oxide) has built up between the electrical components.
This is so common that it can be assumed to be a normal maintenance activity.
The connections from the power to the track, between the tracks and between the engine wheels and the track.
Setting up on a table top allows for convenient troubleshooting.
A voltmeter provides a good tool for efficient analysis of the electrical circuit.
Using a soft cloth rub/polish the rails to eliminate oxide/grime built up.
Use an eraser to scrub the connections between the rails,
I've included several links to provide you with examples of problems and solutions.
Merry Christmas
Hope this helps?
Troubleshooting Ready To Run Lionel Train Sets
Setting Up Your Lionel Train Set
How To Fix Problem With Lionel Fastrak With Voltage Drop Fastrack Connection Pin Fix
Only runs in reverse, why?
Polar Express only runs in reverse ' O Gauge Railroading ...
ogrforum.ogaugerr.com/topic/polar-express-only-runs-in-reverse
Dec 7, 2011 - Polar Express only runs in reverse ... At this time of the year all Polar Express trains are programmed to run North only. ... This would not be so bad on the Strasburg set because half the time, the prototype runs in reverse.
both trains only go backward - Classic Toy Trains Magazine
cs.trains.com > ... > Forums > Toy train operating and collecting
... trains that i set up around Christmas. The first train, according to the box, is a k-line 0/027 gauge dual motor mp-15. For a long time it has only run backwards.
no forward only reverse - Model Train Forum - the complete model ...
www.modeltrainforum.com > Scale Specific Model Train Forum > O Scale
Oct 18, 2009 - 10 posts - ‎3 authors
There are two switches under the cab; they have no effect on forward motion. This setis 2 or 3 years old and has been run maybe 1 hour total. New Athearn HO Locomotive won't go in reverse ...
Mar 5, 2015
Lionel Rio Grande 8213 only runs in reverse - Model ...
Nov 18, 2013
More results from www.modeltrainforum.com
The train keeps jumping off the track
Is the track properly and carefully put together? Is one or more sections damaged take one of the cars and gently push it around watching in those places where the train derails. If it only happens at a track joint look at it more carefully.
2helpful
Peg perego train only goes backwards, but doesnt have a reverse and forward button. please help
funny, you can fix this real easily, you just need to flip flop the cables on the motor, currently the polarity is reversed, theres only two wires connected to the motor just switch them around
Perego Choo Choo will make noise, but won't move
the sounds are run off of a different battery source, check the battery under the seat and make sure that its connected
Our choo choo express train won't start...is it the battery...how can i fix the battery that has charged at least 24 hours
check the battery and the charger with a multimeter and make sure that its putting out at least 6 volts
2answers
Brio remote control express doesn't move anymore
I wish I could help - I have exactly the same problem! Train opened Christmas Day, worked ok. Batteries seemed to gradually die 2-3 days later. Replaced all 3 sets of batteries twice, but nothing. Initially I got sounds, but nothing now.
Top Crafts & Hobbies Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Carolyn Rogers
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
