SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
It is supported for Vista according to this chart
Here is the drivers for 32 bit Vista
SOURCE: Konica Minolta Bizhub c203 printer
where do u scan e mail or folder? if e mail your smtp server ip may have been deleted/changed if folder the path may have changed/deleted or password changed on the server/desktop
SOURCE: The print margins on my Konica Minolta Bizhub c203...
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
SOURCE: I just replaced my Imaging
what image unit did you replace? is there any codes??? more info is needed
