Uniden DECT 6.0 Cordless Phone Logo
A
Anonymous Posted on Nov 28, 2016
Eniden Premium dect. Wont ring. Makes a continual sound when picked up. Unable to get onto messages. Mobile alerts me. When ringing a number sounds engaged.
5 Related Answers
johnychel
isaac johny
  • 796 Answers
  • Posted on Nov 19, 2008
SOURCE: have nokia 3120 , incoming call does not rings
check if the format of ringtone set is compatible with your phone..
try to restore the refactory settings once.
thankyou.
Anonymous
  • Posted on Mar 03, 2009
SOURCE: ring tones for my lg vu cu920
It must be under 300 kb.  Lame, I know, but that's the way it works.
If you want a ringtone for a specific contact, then your contacts must be kept on the phone, not the mem card, only.  I keep 'em both places, just in case.
Anonymous
  • 37 Answers
  • Posted on Apr 29, 2009
SOURCE: Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
k24674
  • 8093 Answers
  • Posted on Sep 14, 2009
SOURCE: I have the DECT 6.0 and My hand set wont ring
Ringer may be muted (turned off).
If you need a manual to check correct procedure, here is a link.
http://www.uniden.com/index/manuals_results.cfm?cat=59
Select model and download manual.
Hope it helps.
Anonymous
  • 8 Answers
  • Posted on Jan 04, 2010
SOURCE: w890i wont ring or do text alert. In all other
Get mobile help from
http://www.dingdongringtones.com
4helpful
How do I change the number or rings on my vtech cs6619-2
The CS6619-2 isn't an answering machine. It will continue to ring until someone or something picks up, or the caller hangs up.
To change the number of rings before your answering machine picks up, please consult the documentation for your answering machine.
3helpful
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
1helpful
2answers
I would like to block 1 number who makes nuisance calls and sms messages, the phone I have is a 2720 flip.
well the only option is that u can request ur network carrier to block that number for u.
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
How do I increase the rings before message answers?
Setting the Number of Rings (Excerpt from the Uniden Dect 1580 Phone manual
The ring time setting allows you to set the number of rings the caller hears before your answering system plays the outgoing message. You can set the ring time to answer after two, four, or six rings. If you enable the Toll Saver (TS) setting, the answering system picks up after two rings if you have new messages, and after four rings if there are
none. This way, if you make a long distance call to check your messages, you can hang up after the third ring to avoid long distance billing charges.
  1. Press Menu/Select.
  2. Select the Ans. Setup menu, and then the Ring Time submenu.
  3. Move the cursor to select a ring time (Toll Saver, 2 Times, 4 Times, or 6 Times).
  4. Press Menu/Select. You will hear a confirmation tone.
thanks
8helpful
Would like to increase number of rings before answering machine comes on.
1helpful
2answers
My Motorola A455 has stoped ringing when I get a call or text message. All my settings are on ring only and the master volume is on high. The speaker option is also not working. Please help! Shido
Oh seeeop the same happened to me and the reason is that the speakers on the phone probably blew out. Your best help will probably be to take it to the phone company and ask for them to fix it. U really can do nothing just messing with it in fact that makes it worse.
1helpful
Not working ringer
menu
2 settings
3 tones
incoming call alert (set to ringing)
ringing tone ( pick your ring tone)
ringing volume (set to level 5 loudest)
vibrating alert (on)
message alert tone (pick tone)
instant message alert tone (standard)
keypad tones (on)
warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok
alert for (all calls)
Jul 03, 2009 • Nokia 3100
I need to change the sound of the ring the alert makes when I receive a voice mail message....I don't like the way that one sounds. I looked everywhere on the phone but can't find it. You know, when you...
please go to profile and choose general and get edit menu,get tone setting or alert or ringing tone then you can get number of tones there and you can choose one from there
1helpful
4answers
I cant change my message alert tone and alarm tone
Go to Menu, Click on settings, Audio & Ringtones, Message Alert Tones.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
