Televison & Video Logo
M
Mohammad malik Posted on Nov 28, 2016
Samsung tv led un40h5203afxza no picture no voice only broken line around the screen
5 Related Answers
Anonymous
  • 4234 Answers
  • Posted on Aug 28, 2008
SOURCE: Samsung HLS 5679W LED DLP TV Horizontal white lines jagged across screen.
What you are sseing is a convergence problem within the light engine of the set. This is not repairable in teh field other than replacing the light engine part. Since this unit is less than one year old, it should be covered under warranty. From the looks of it, one of the LCD panels has shifted internally. Call for warranty service and indicate that the light engine has a problem. With luck, the service company will show up with the part in hand. Replacement should not take more than an hour or so.
Dan
smarthome2
Frank Fulton
  • 1114 Answers
  • Posted on Jan 11, 2011
SOURCE: i have a new 37
should be a button on the remote that says "P.Size" Every push of the button changes the Aspect, should be set to either 16:9 or Full. Hope this helps. If you do not have the remote, you can access thru the menu button on the set and toggle thru on screen display to Viseo and adjust it there as well. Hope this helps.
Anonymous
  • 33 Answers
  • Posted on Mar 11, 2011
SOURCE: Samsung 40" LED TV Display
Not familiar with this particular model of samsung LED TV, but ghosting and shadowing are usually an accepted manufacturer's defect.
If you're still under warranty or within 30 days of purchase, contact the company that sold you the TV or Samsung warranty department.
If you're out of warranty and you don't wish to deal with this, contact a TV repair shop. They will most likely tell you that it's not worth repairing and recommend you purchase a new TV.
Anonymous
  • Posted on Nov 24, 2011
SOURCE: Samsung 55 UN55D7000 55 3D LED TV Has started a
I have a similar issue on mine but without snD issue. This happened once before and went away but just came back
Anonymous
  • 1182 Answers
  • Posted on Jul 31, 2012
SOURCE: samsung 32" LED TV Purple Line Horizontally across top of screen
Can you please change the input device to some other you know, works? If you do not notice any problem there, look for the aerial cable going close to any power line or has interference from some other transmissions of any kind nearby.
Black screen Samsung tv
In most of the case the problem is the LED back lights. You may disconnect the cable between the power supply & main board, supply the AC to the TV, the back lights should light up, if not replace all of the LED back light strips,
I just replaced led strip on samsung un40h5203afxza tv. It works but I am now getting faint horizonal lines over the screen. How do I fix this?
I hate to give you bad news but you damaged the LCD panel when you had it out and its either live with the lines or throw the TV away, its easy to damage the panel when handling them
T con board question for samsung smart tv
With most of the modern model LED TVs from Samsung, the T'Con board is a built in part of the display panel, and is not replaceable. If you wish to get some details; check the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from www.cnet.com
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Samsung 50" led un50h6350. The TV is about 18 months old and the picture went out, the audio and back light are working. I've replaced the t-con board and that didn't fix it. Someone please help!
Samsung LED TV Screed goes blank periodically for 1 sec - Forums ...
CNETJun 11, 2015 - Lately, my Samsung LED TV's screen will black out from 1 -2 seconds then come back. The TV has been ... The TV is about 6 months old. .... I've only notice this when I'm watching in HD. ... by Stlouib / January 13, 2012 11:18 PM PST ...Mine does the same thing - picture goes black for 1 - 2 seconds and then comes back. Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Are there still capacitor problems with Samsung TVs?
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Flashing led light
Sounds like the circuit board may need to be replaced. Mine did a similiar thing only my picture turned upside down, screen went blank yet had good voice. Samsung tech said the 2 circuit boards were bad and had to be replaced at a cost of $780 in parts plus labor. I bought a new LCD TV, not Samsung.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
