Not sure on this one but it might be the heads in your vid cam may need cleaning.
or the tapes are not running straight on the heads or the rollers in side.
if the vid cam has been in a cold place it can cause this fault as the heads may have a bit of damp.
try putting a tape in and run it fast forword in play mode and see if starts to clear the playhead.if it does keep doing it until you see a clear picture.
this could also be a head misalignment fault if it is you will have to take it to some one to have a look at.
if any of the above does not work then you will have to take to some one to look at it.
Testimonial: "I will try this. I had left it in the car during the day on Friday and it was a very cold day so this could be the reason. Thank you for your help and prompt response ??"
could you please let me know if running the tape through it worked or not.thanks.
you are very welcome hope it does work for you.
Hi Noel, it's worked a treat, thank you. I feared that I'd list all the memories but they are still there. Thank you again Noel ??????
you are very welcome glad i was able to help you out.how did you do it in the end?.
I pressed play and fast forwarded it to the end, then I rewound it whilst playing. The images started to show up on the rewind with black lines going through it, so I repeated the exercise and then the full images appeared. I checked all tapes and they all play great. Thank you once again Noel x
thank you for letting me know.now if some one ever says to you this is what my cam is doing you can tell them how to fix it and they will be amazed that you new lol.anyway all the best and you never no i am have to help you again lol.
