Washing Machines Logo
t
ted kleban Posted on Nov 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do u change the drain hose - Washing Machines
AJMAL KHAN
Level 2:
  • Expert 388 Answers
  • Posted on Nov 27, 2016
AJMAL KHAN
Expert
Level 2:
Answers
388
Questions
0
Helped
110147
Points
869
Open the back cover and disconnect the drain hose and replace it gently.
My zwf 16581 w zanussi shows E32 error code. I have replaced the pressure switch but nothing has changed. Please help
If you are replacing an analogic pressure switch and nothing has changed I suggest you the following:
  • Drain the water from the tub.
  • Are pressure switch hose and air trap system free? (You can disconnect the hose and blow in it to check if the system is free).
  • If YES, than check the draining system (filter, drain pump, drain hose). Is the machine draining correctly?
Dado
2answers
How do i change the coolant in 2000 dodge intrepid?
Should be a drain plug at the bottom of the radiator, if not you can disconnect the lower rad hose at the radiator. Remove filler cap to allow air in as coolant drains. Catch and dispose of drained coolant as it is sweet and animals will drink it and die
Kenmore he5t washer Changed the pressure switch.
F21 means long drain. Yes, there is something be in the hose. You need to open the filter and clean the pump, too.
Ge washing machine will not drain
Drain by lowering main drain hose below pump into shallow bucket, remove front lower panel , take large hose off back of pump clean out hose, may have to take 2 screws out of pump mount to look in pump mine was being stopped by a nail,the$6.75 in change was still in the hose
Load water, and without spin start discharge water. Control card I change, all contacts I clean. Motor dasn't rotate. What can be? maybe motor brash?
see this causes and fix it. God bless you
Water drains out while it is filling
  • Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  • The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
Change drain hose
Should be quite simple to do Eddie. Its secured by a clip onto the pump outlet undo this fit new hose resecure .Fully Watertest before use ..
1helpful
Water in the bottom and not working
Check for a clogged drain (e.g.: via drain hose), or a water pump malfunction due to foreign obstruction (e.g.: glass, etc).
Note: If you changed a food waste disposer (kitchen sink area) and did not remove "plug" from disposer for dishwasher drain hose (assuming dishwasher drain hose connected to food waste disposer), then water cannot drain from dishwasher.
Change my dehumidifier from draining by hose, to reservoir
I don't have the exact dehumidifier as yours, but on mine it's as simple as removing the hose, then the water fills the reservoir. Does it look like yours will do the same? If so, the hose fitting is also a sensor that will shut the unit off when it is full to avoid leaking onto the floor.
How can I change the drain hose?
Hi, The lower front panel comes off and then you can see the drain hose attached to the pump. Part # 40053901 @ $19.95 for the long drain hose. I hope this helps. If I can assist you further, please let me know. You can find this hose on my web site www.whirlpoolpartssurplus.com
Vic
Top Washing Machines Experts
john h
