2009 Buick Lucerne Logo
D
Davis Barefoot Posted on Nov 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2009 Lucerne is blowing the ECM 10 amp fuse. Seems to do it after a right turn and acceleration. The circuit has ben traced but no issue was found. Said it could be a short that is hard to find.
mika
Level 3:
Master:
  • Master 469 Answers
  • Posted on Nov 28, 2016
mika
Master
Level 3:
Master:
Answers
469
Questions
0
Helped
224935
Points
2864
  • GALAXY S7 EDGE CASE: Combination of clear hard back panel + soft flexible edges = excellent protection showcasing your Galaxy S7 Edge. Compatible only with Galaxy S7 Edge.
  • BEST PROTECTION: The lips on both front and back protect the screen and the back panel from scratches
  • SCRATCH RESISTANT BACK COVER: Premium Japanese polycarbonate with scratch-resistant coating will keep your help your case endure scratches and scuff marks more than a regular case. Longer life and cleaner look for your case and for your Galaxy S7
  • IMPROVED GRIP: Flexible rubber edges of this clear case for Galaxy S7 Edge hugs each and every corner of your Samsung Galaxy S7 Edge and allows you to get a better grip
  • German TPU rubber bumper edges and Japanese polycarbonate back cover are infused using the latest technology.
AmanStino Galaxy S7 Edge Case Hybrid Scratch Resistant Back Cover with...
2009 Lucerne won't come out of park after changing 4 fuses
Interlock associated...
Rear fuse box underneat rear seat.
RAP 1, fuse 28, 10A
RUN 2, fuse 10, 10A
RUN RELAY
RAP HC RELAY
All the above need to have power for brake/trans interlock release.
https://www.google.com/amp/s/fuse-box.info/buick/buick-lucerne-2006-2011-fuses-and-relays
2answers
I just replaced my ecm in my 2009 Pontiac g5 and it keeps blowing the ecm fuse as soon as it touches the terminal. What could be the cause of it blowing like that Everytime I try to replace the fuse?
Sounds like you have a short somewhere in the ECM harness. Chances are that the original ECM wasn't going bad, it has likely been a wiring issue the whole time. If you are no good at trouble shooting wiring issues, you need to find you a competent mechanic.
How is my buick lucerne 2007 is blowing fuses to the ecm?
Can't guess
The car needs to be in a shop for the answer,
not trying to use it & replacing fuses at a dollar ea
Short on a 10 guage wire 20 amp fuse 1994 winnebago vectra. Do NOT KNOW WHAT IT SERVICES TO TRACE SHORT
Go to your local electrical supplier and they will rent you a signal generator. With it you connect to the circuit at the breaker box and you can trace the circuit through finished walls.
murf427
2answers
1993 rodeo not running no power to fuel pump
if there is no power to the fuel pump check relays and fuses....UNDERHOOD FUSE & RELAY PANEL IDENTIFICATION Fig. 2: Underhood Fuse & Relay Panel Identification Courtesy of ISUZU MOTOR CO. Fusible Link Identification ? A - 80 Amp (1991-92 3.1L) ? A - 60 Amp Main-1 ? B - 30 Amp Main-2 ? C - 30 Amp (1993-94) ECM (3.2L) ? D - 30 Amp Condenser Fan (A/T Models) Relay Identification ? 1 - Headlight Relay ? 2 - A/C - Heater Relay ? 3 - Starter Relay ? 4 - A/C Compressor Relay ? 5 - Charge Relay ? 6 - Fuel Pump Relay ? 7 - ECM Relay ? 8 - Wiper Relay Fuse & Circuit Breaker Identification ? 1 - 15 Amp (1991) ECM, Fuel Injection System ? 1 - 15 Amp (1992-94 2.6L) ECM, Fuel Injection System ? 1 - 10 Amp (1992-94 3.1 & 3.2L) Heated Oxygen Sensor, Fuel Injection System ? 2 - 20 Amp (1991-92) Fuel Pump ? 2 - 20 Amp (1993-94 2.6L) Fuel Pump ? 2 - 15 Amp (1993-94 3.2L) Fuel Pump ? 3 - 10 Amp (1991) ? 3 - 15 Amp (1992-94) Turn Signal Lights, Hazard Warning Flasher Lights ? 4 - 10 Amp Horn, Door Locks ? 5 - Not Used (1991 3.1L) ? 5 - 10 Amp Charging System, Charge Warning Light WARNING: Always disconnect battery ground cable before servicing "high- current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician. Page 1 of 2 FUSES & CIRCUIT BREAKERS -1994 Isuzu Rodeo LS? 6 - Not Used (1991) (1992-93 2.6L) ? 6 - 10 Amp (1992-94 3.1L & 3.2L) A/T Interlock System ? 6 - 10 Amp (1994 2.6L) Heated Oxygen Sensor, Fuel Injection System ? 7 - 20 Amp Heater/Air Conditioning Blower Controls ? 8 - 10 Amp Air Conditioner Compressor Controls ? 9 - 10 Amp Right Headlight ? 10 - 10 Amp Left Headlight © 2008 Mitchell Repair Information Co., LLC.
Underhood fuse block swap out relay #7 thats the ECM relay.
Ground Circuits Using a DVOM, touch negative voltmeter lead to a good ground. Touch positive voltmeter lead to each ground terminal. With vehicle running, voltmeter should indicate less than one volt. If reading is greater than one volt, check for open, corrosion and loose connection on ground lead. See ECM GROUND LOCATION table for ECM ground location.
Page 1 of 1 SYSTEM/COMPONENT TESTS - 2.6L EFI -1994 Isuzu Rodeo
1helpful
I have a 97' f150 4.2 eng 2 wheel drive pickup elect. problem
A fuse blown is a short, and a short is a ahort.
The fuse is the ecm so unplug the ecm and see what happens. If the fuse holds with theecm unplugged, then it is your ecm that needs relacement. If it still blows, The short is in the wiring.go to the parts store and pick up and automatic circuit breaker. It plugs in where the bad fuse goes. It will trip and reset itself automaticallly like a flasher until you have located the short. trick, Start with a breaker of amp. examole; if you took out a 20 amp, put in a 10 amp so the breaker trips faster, On and off quicker so you don't have to wait between ressets. If you want to trace the short by the wiring, put a 25 amp or with great caution a 30 amp. That is the limit. The wire will get warm on the 25 and even warmer on the 30. Pay attention that the wire does not get hot. Hopefully yhe 25 will get the wire warm enough for you to follow. Good Luck, Ned. This method is dangerous if you don't pay very close attention using the high amp breaker. There is a risk of fire if the circuit cannot handle 30 amps. In fact, only yuse the 30 amp breaker if the 25 breaks and resets too fast. Good Luck_Ned_
2answers
2009 e250 keeps blowing 10 amp parking fuse then
if it keeps blowing the fuse you have a short in the wiring
2001 S-10, Blowing "ECM Batt" fuse after running for about 30 min
that fuse feeds power to fuel pump relay circuit that feeds pump could be defective pump,or damaged circuit wires that shorts out! and not a good idea to put higher fuse in circuit could cause more damage to circuit! but i know when your stuck, u do what it takes,so inspect circuit related to fuse,
Top Buick Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
