SOURCE: I have an american standard
Check the air vacuum switch and line as you may have a air vacuum leak. The button that controls the on and off to the jets is an air vacuum switch....It may have a slow air leak in the line or connections that is activating the on and off control
SOURCE: american standard air tub motor hums
That motor solution is correct. I called the company American Standard and fortunetly, mine was still under warranty. They sent out a plumber within 3 days to replace the motor and now I'm back in Kansas Dorothy.
SOURCE: American Standard Motor humms
I think there is a clear or black tube connected to the pump on the back of the black box on top of the pump motor, there is a nut where the tube attaches to the back, unscrew this nut and pull the tube out. If it is not the tube type switch, the pump motor power plug should be plugged into a black or blue control box, this box should have a wire going to the switch in the tub. If you have a buzzing noise, the pump or motor is probably seized, This is caused from lack of use or using bath oils or soap in the tub, When you get the pump and motor out to check, stick a screwdriver in the back of the motor(center of motor hole may or may not have a plug in it) and turn the screw, itshould spin freely with little or no resistance.
SOURCE: how do you remove the jets on an american standard whirlpool tub
The jets have a nut on the back of the jet. I hope you have access or else you will need to pull the tub for this job. Loosen the nut and squeeze aquarium grade silicone in between the tub wall and the nut, Tighten the nut, but not to tight. Let set over night fill and check for leaks the next day.
SOURCE: Jetted bath tub has stopped working. Motor hums
I had this same problem on my tub, which uses a GE motor. I looked at the motor, and on one end (the end opposite where the water comes out) there is a hole in the middle. In that hole is the head of the shaft, which has a regular screw tip. Turning this turns the motor. I filled the tub, inserted a slotted regular screwdriver and turned it about 10 times clockwise, then 10 times counterclockwise. You should see the whole motor turn. Doing this loosened it up, and then it started.
Once it started, all kinds or residue came out, which was probably why it had stopped working. I hadn't used it for a while.
After getting it running I'm going to run some cleaning solution through it, and make sure I run it more often to prevent this in the future.
I'm not a professional, just a guy trying to fix his own tub. So take my advise with that grain of salt.
Replacement Air Switch will cost you about $20
US Parts Center
Hi
If the washer won't fill you'll need to check for the water
inlet hose, the water inlet valve and the pressure/water level switch assembly.
Inspect the inlet hose coming to the washer for any blockages. If the hose is
not clogged then check the water inlet valve for any clogs, if the water will
not even fill for few seconds then certainly the water inlet valve is bad and
should be replaced. You can also use a multimeter to check continuity on inlet
valve. If you don't get any value on the multimeter then you'll need to replace
the water inlet valve assembly. However, if the valve is fine then the
pressure/water level switch assembly should be replaced. Hope this helps...
Please post back if you need more information.
Daniel
