Question about Kaz Dryers
KAZ DD- TEC10E SWITCHES ON LIGHTS UP BUT THATS ALL, NO FAN
2 Suggested Answers
SOURCE:
K3rn3lkill3r
  • 72 Answers
SOURCE: Duracraft Dehumidifier White/Grey Dd Tec10e manual
Goto http://www.duracraft.com and click on the "humidifier" button to the right. The products listed there have the owners manuals available in pdf format. Hope that helps.
Posted on Dec 02, 2009
Where is the fuse on a honeywell quiteset hy-108
KAZ Inc. has franchised the use of Honeywell's company name to manufacture/market this KAZ OEM HY-108 Tower Fan. The small 2.5A fuse you are looking for is located inside the 2-Prong Electrical Outlet Plug. This tiny 2.5A Fuse can be hard to find as a replacement in retail Hardware Stores, but see if you have an old LONG string of indoor/outdoor Christmas Lights... some of these Christmas Lights Strings may have the correct 2.5A Fuse you need. IMHO, it's strange that KAZ Inc. did not put instructions in the Honeywell HY-108 Owner's Manual where the Fuse is located!
May 31, 2012 | Honeywell Hy108 Tower Fan
Have dual light switches - one for fan one for lights on fan. incoming to box is white (neutral) black(hot) then out to switches two sets of w/b. fan has one each of the white, black blue(lights). How do...
From your switch box to your fan run a 14/3 wire. Take the incoming 14/2 white wire,and connect to white of the 14/3 wire to fan lite combo ,and hook both white wires from fan and lite. Hook the fan black wire to the black wire from the 14/3 Hook the black wire from the fan to the red wire from the 14/3. Then go back to the switches, and add a black and red pigtail about 4"long to the black wire from the 14/2, now connect the red wire to one side of switch, and the other red wire from the 14/3 to the other side of switch. Do the same to the black wire on the other switch.
Sep 17, 2011 | Garden
Last night both fan and lights worked on my hood fan and lights. This morning neither are working. Checked house fuse box - everything ok there. what could be the problem does the allure have a fuse inside...
could be simething as simple as a disconnected wire, prior to calling for help, check these items if you feel okay with that , first turn off the circuit breaker and where the house wires come into the unit,, remove the wire nuts and check for burned areas,, if thats ok, reattach them and move to the switch or switches, unhook the wires, ( make note where each one goes ) and check them with a meter , this is probably where your problem will be,
Jul 10, 2011 | Broan-NuTone Allure QS130SS Kitchen Hood
I need the plastic support piece that mounts to the base Model #DS1600 duracraft oscillating fan My piece is broken
You will need to contact KAZ for your part at
Telephone
1-800-477-0457
Call center hours
Ordering: 24 hours/7 days a week.
Customer Service: M-F 8:00AM-7:00PM EST
Mail
Kaz, Incorporated
Attn: Consumer Relations
250 Turnpike Road
Southborough, MA 01772
Outside of the U.S. and Canada
Asia Pacific kazasiahelp@kaz.com Austria info-austria@kaz.com Benelux Info-benelux@kaz.com Central & Eastern Europe info-cee@kaz.com France info-france@kaz.com Germany info-europe@kaz.com Iberia info-spain@kaz.com Italy info-italy@kaz.com Scandinavia Info-europe@kaz.com Switzerland Info-europe@kaz.com Turkey & Middle East Info-europe@kaz.com United Kingdom enquiries@kaz.com All Other Europe info-europe@kaz.com
Retailer and Dealer Inquiries
Send email inquiries to CustomerRelations@kaz.com
Minimum order requirement for accounts.
Jun 04, 2011 | Heating & Cooling
The light fixture needed to be repaired. It never worked when I bought the house. New light bulbs didn't worked. I replaced the two ceramic light switches that had corroded wiring and reconnected blue to...
if its a duel switch that controls lights, and the fan seperately. sounds like the power for the lights is going directly to the fan, and therefore making the lights work also. also check out switch, make sure power is only going to the lights, with light switch on.
May 01, 2011 | Heating & Cooling
My Duracraft DD-TEC10E dehumidifier has come up with an E2 message that I cannot clear to make it work, any ideas?
DIY fix for Duracraft TEC10E E2 error, in case it's useful for others:
(When I tried to get a replacement temperature sensor via UK/Ireland support (kaz.com -> www.hot-europe.com) I was told that a replacement sensor was not available, nor was my unit serviceable).
Anyway, after a bit of messing with a variable resistor, I found that it would trigger E2 at a resistance of 560-580K, and also at resistance < ~1K (I stupidly destroyed the faulty temperature sensor trying to take it apart, without first checking what kind of resistance it presented, so I don't know whether mine broke OC or shorted).
Assuming an NTC thermistor, and a threshold of 0degC - the sensor is just to stop the dehumidifier cooling coil from icing up AFAIK - a 150K NTC thermistor with 'B'(25/100) value of 4400 should give a suitable replacement, with a 0degC resistance of 579K.
I wasn't able to find an exact such replacement, but I got a 150K/B~4000 from Maplin, put a 170K resistor in series, sheathed it up and installed it, and initial results look good - putting an ice-cube on the new sensor will trigger an E2 on the unit.
YMMV.
Nov 29, 2010 | Dehumidifiers
Duracraft Dehumidifier White/Grey Dd Tec10e manual - can I get a copy of this manual? I have this product in my flat but the landlord is unable to find the instruction manual
Dec 02, 2009 | Cars & Trucks
Dryers Logo
49 people viewed this question
Top Kaz Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Kaz Dryer Expert? Answer questions, earn points and help others
