Electronics - Others Logo
B
Briansaville Posted on Nov 26, 2016
What does opp stand for on a motor master 3000 watt inverter
Just connected my 3000 watt inverter, and turned-on, power light comes on then goes out, showing opp on the readout, any thoughts
Pierre Curtis
Level 1:
  • Contributor 33 Answers
  • Posted on Dec 07, 2016
Pierre Curtis
Contributor
Level 1:
Answers
33
Questions
0
Helped
31568
Points
52
Unit is shutdown with display showing "OPP"
Inverter is short circuit and has shut down.
Reset to normal operation by using manual switch
  • alvin young
    alvin young Nov 14, 2021
    I try that and still the same
5 Related Answers
Anonymous
  • 242 Answers
  • Posted on Oct 24, 2008
SOURCE: power inverter
Most likely a fuse. Check for a fuse on the inverter itself or one inline with the plug. Usually you can screw off the tip of the plug and replace the fuse inside.
Anonymous
  • 4 Answers
  • Posted on Mar 03, 2009
SOURCE: 2nd season with 400 watt vehicle 1024 inverter. The
Restating the question - 400 watt inverter is turned on and running with the vehicle turned off.
After starting vehicle the red light of the inverter is on with no power output from the inverter.
If you turn the inverter off then on inverter operates normally.
Solution - this is normal operation - my inverter does the same thing. When you start the vehicle
it draws a lot of current from the vehicle battery which causes a drop in battery voltage. Most inverters have a low voltage input safety and will fault the device.'
If the problem is turn on inverter then the red light starts flashing... I am thinking you
have the same problem as the one I replaced - it broke... I am sure some capicator
or other component in the circuit failed... My solution was to purchase a new one...
Anonymous
  • 4 Answers
SOURCE: Low voltage output from inverter
I am thinking this a high impediance device problem and this is normal operation - the user manual of my inverter warns about use with high impediance devices - if not I am interested also...
nitrospawn
Ibe Chukwudi
  • 290 Answers
  • Posted on Feb 26, 2010
SOURCE: I HAVE USED THE NEXXTECH 175 WATT POWER INVERTER
have you charged it,and check if the battery is still ion good condition
nitrospawn
Ibe Chukwudi
  • 290 Answers
  • Posted on Feb 27, 2010
SOURCE: Vector vec 051D 3000 watt fan won't run anymore, unit overheats
your inverter needs to cool at all times , if the fan does not work,try buying a small standing fan to blow cool air to you machine, it is possible that your heater is making the inverter to over heat please avoid using the heater on the inverter
1helpful
My 3000 watt aims inverter/30amp charger seems to work but the charger will not charge/transfer when I turn on the generator. Charging indicator will not come on. It does transfer the generator power
dear see that :
1- the range of voltage which inverter work between it for example 180-260 v
2- most small generator voltage reach more than 260V so the inveter not work
3-check the frequency of genaratoer if it not fix the inverter will mot work
Inverter problems
3K is a big inverter. Depending on mfr, though, inverters put out numbers for PEAK, not AVERAGE Watts, and have trouble supplying large amounts of surge current on demand. Some appliances with large motors present large turn-on demand, like A/C's, washers, ovens, and fridges and will give converters trouble.
Your Microwave, if it's a big one, like a 1.2 or 1.3KW will ask for a lot of juice when it first turns on. But once it's on for a few seconds will probably be OK.
Get a bigger or different inverter, or a smaller microwave.
My 3000 watt Duracell inverter will not start a 1 1/2 hp electric motor. The voltage drops to 45v and the electric motor struggles to reach full rpm. This is a table saw with no load. The generator revs...
have the saw motor checked for internal and wiring problems
check the start/run capacitor of the electric motor
running a 1 1/2 hp motor (1075 watts) on a generator that has a running wattage of around 2250 watts means that it should start and come to speed immediately if the motor is good
the problem indicates that there is a circuit problem in the saw motor that is exceeding the available wattage (3000 watts ) on start up
Cobra inverter powers up but no power and it flashes OPP
the OPP error is an indication that the AC load "output" is short circuit. Try disconnecting the AV load-device and attempt to try again. Use a lamp or other suitable to confirm that the inverter is pr is not working properly.
It is possible that the load (device) that you have connected either exceeds the inverters power rating or is in fact shorted and the inverter is working properly.
If the opp flashes with no load attached it is likely that the inverter has developed an internal failure.
Hope this helps?
I bought two veco51d 3000 watt inverters made by vector and conectted with two positive and two negative cables to a good battery 12.6 volts load test at 750 cranking amps and both inverters light up and...
Hello, I hear you. Was the reason to supply 240 volts? When you try the inverters separately, do you get 120Volts output? Let us look at the units working individually first and go from there.
I have a vector 3000 watt inveter red fault light is on, wont power a 6.5 amp fuel pump
Check that ground is correctly connected. If nuetral is provided, ensure it too is connected. Your total load is 780 watts. Check power in and ground out of the supply side. There may be a fuse in the inverter on the output side also, replace if necessary. If fault light does not go out after these checks, you will need to contact Black and Decker who manufactures the vector series now.
2answers
I have a cobra cpi2575 inverter and the led screen keeps saying OPP even after i unplug everithing exept the power cables
We hope it is still new and can be returned, do it as fast as possible.
You will find it hard and very costly to repair it.
Starting ad 75.00 an hour with the bill being around 175. before your running again.
If at all possible Return it and consider it a lessons learned and purchase an nicer Pure sine wave inverter in the 1500 watt size area. they tend to be much better and are much more capable of running full time under a load.
Sad new I'm sure for you SORRY. I'm a Seven inverter owner with only one good inverter to show for all the trouble.
r/ David
1helpful
Xantrex 2412 will not open my Chamberlain Lift Master Prof. door
That must be a pretty big door opener. Problem is probably the motor's starting current draw. Most AC induction motors pull 5 to 7 times their rated running current when starting from a dead stop. (about 7,820 watts) That's much more than the surge capacity of a 2.4 Kw inverter. Sounds like you need a bigger inverter or a smaller door motor.
1helpful
2answers
Top Inverter Electronics - Others Experts
Ngoro
john h
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
