Exercise & Fitness Logo
Leland Guillemin Posted on Nov 26, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Horizon Treadmill Ct5.1 turns on, displays nothing and beeps nonstop
I moved the treadmill and now when I turn it on it just beeps like crazy. It doesn't display anything on the screen and when i press buttons, nothing happens.
greg kinsley
Level 2:
Novelist:
  • Expert 145 Answers
  • Posted on Jan 03, 2017
greg kinsley
Expert
Level 2:
Novelist:
Answers
145
Questions
0
Helped
83168
Points
273
Hi There....sounds like a stuck key on the membrane? Safety key installed?
Electro Med Services
Level 3:
  • Horizon Master 6,694 Answers
  • Posted on Nov 27, 2016
Horizon Master
Level 3:
Answers
6694
Questions
Helped
1872443
Points
21433
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
HORIZON Treadmill CT5.3 out off work
If you wish to get some details; check the site linked here. Pull up older posts.... http://electro-medical.blogspot.com/
What is causing my Treadmill T202 to display a "connection" and make a loud beeping sound?
you should remove the motor cover and inspect to see if you can locate where is came from. check the incline motor
1helpful
Horizon Treadmill won't run?
Check this attached link for trouble shooting information
2helpful
Ti22. Power turned on display screen blue but no text display. No controls work, no beeps when any buttons pushed.
Power board may have shorted. Check all fuses and connections. Check for loose wires. May need professional services.
Horizon t207
follow this steps and fix it. God bless you
1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
30helpful
2answers
Horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
Top Horizon Exercise & Fitness Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
