There are literally thousands of different flashlights & there are dozens of different possible answers to your question - depending on the specific flashlight you may have...
BASIC THINGS TO CHECK:
* unscrew the battery compartment, new battery opperated items often have a thin piece of plastic separating the battery from the unit's contact terminal to prevent battery drainage. Remove that piece of plastic (possibly sticky'tape), screw the unit back together & test again.
* if it's a rechargable flashlight, try charging the unit.
* if it's not a rechargable model, replace the batteries with a fresh set & test again.
>> if all else fails, Consult the User's Manual...
they most likely mention the solution on the 1st page of the manual.
This is usually not the power board. the LED strips fail and you have 55 LED bulbs in the back light. It is not an easy fix because the display is glued to the bezel and if you don't take extreme care when working on it, you crack the LCD display.
To take the charge the inbuilt battery must be functional. Once the battery goes bad you will be unable to charge the unit or it will take a small charge and die rapidly thereafter.
You may or may not be able to change the battery. It depends on the manufacturer of the product so you should consult the instructions that came with the item if you still have them.
it's telling you the battery is fully charged so suspect that either the battery is dead or the bulb is burnt out. Get a test meter and test for voltage at the battery. If yes, then the bulb is burnt. If no voltage then obviously the battery is bad
No, that is not due to battery. Your mouthpiece or receiver's earpiece might be bad. To make sure, please record something and try playing it. If you can hear what you recorded, your mouthpiece is fully functional. Now test whether the receiver earpiece is not working. Tell the receiver to set his phone is speakerphone mode. If he can hear what you say in speakerphone mode, then the receiver's earpiece is not fully functional.
Hope this helps.
The unit is 3 individual flash lights. Pull one of the flashlights by the head (the light part) it will come out easily once you know what you are doing. The other two may be pulled out in the same manner. The bottom will then unscrew where you will be able to replace the AA batteries. Each flashlight will then go back into place very easily. Hint...test each individual flashlight before putting back together to make sure you have your batteries in the proper place and that they are useable batteries.
You will probably not be able to find a battery, those are usually very economically priced and replacement parts are rarerly every available. You may be able to find similar rechargable battery that would work, try a dept. store or hardware store and look in the flashlight section.
No it is a switching issue and is not going to get better.
Kodak technical support will tell you more
be prepared though -if you have had this for some time
then the next camera purchase looms I guess
