I have a 1997 chrysler town & country,my transmission is not working right. my friend he owns a code reader and is giving the code 0700 & code 0760. what part you think it is?
P0700 is a generic transmission code a code reader which reads transmission codes will narrow the code down. P1775 may be from a transmission code reader. found some info on it above.
Hi there: The DTC P0700 is a Information Code The Transaxle Control Module (TCM) that monitors the malfunction of sensors and actuators relating to transaxle control. If any malfunction is detected, the TCM informs the PCM by sending a signal (P0700 code). P0700 means that a code has been set in the TCM. This code is for information ONLY. If this code is present, check for transaxle codes. So basically, the P0700 code is telling you to check the TCM for a transaxle DTC. The TCM can not turn on the check engine light so it has the PCM do it, which can only be done with a diagnostic scanner. The self retreival method for chryslers with the ignition key will not pull up the specific transmission fault codes in the TCM.
Not really something for a do-it-yourselfer unless you have the underlying code. P0700 is a "general transmission fault" code. There is a code under that which can be found by a DRB-III scan tool. If you can find it, you'll know what to fix. It could be as simple as an input sensor for the transmission, or as complex as replacing a mechanical part inside the transmission. The code will tell you where to go.
I have the same vehicle, is your engine light on or flashing? Put your key in the ignition, turn back and forth 3 cycles of on off. End in the on position. If you have a 0700 code come up, your transmission is "done". Sounds like it is in "limp mode". Thats what happened to me. Had tranny overhauled, $1800.
0700 is a "transmission control system malfunction". The entire 0700 series of codes deals with transmission trouble codes in more detail so the 0700 won't tell you much unless one or more of the other codes also were set.
