You just go to the link I attached I'm sure you will get the solution of your problem -
Best Manuals
SOURCE: Kubota mini digger KX36-2: changing rubber tracks
Undo the nut the nipple fits onto ,thats the valve itself.
Then lift up the machine with the arm over the side that the tracks off about 2 - 3 foot so it helps the track to go in and on and start putting the track on at the sprocket end first.
When you get the track to the idler end it will push the grease out as it rolls on or you can lever it home with a big bar before tracking up .
Testimonial: "Thanks for this, I've now got the rubber track back on & retensioned it. The track does need levering home with a bar and that was fairly difficult."
