SOURCE: missing remote for panasonic vcr pv-v4522 and
Is the eject switch one of those plastic type that pushes against a push to make switch (see image below).
If it is you can melt the plastic with a soldering iron so it engages again.
SOURCE: how locate video heads on panasonic pv v4522
The video heads are a large silver cylinder inside the machine.
I will warn you against using a cloth or anything to clean then as they have a small gap on them and if any dust gets in there it could make the problem a lot worse.
Your best bet is to search google or some where for a video head cleaning tape, they should be fairly cheap these days.
If that doesn't make much improvement then unfortunatly the head is probably going faulty which would need to be replaced by a audio visual engineer.
Regards
Mike
Testimonial: "thanks"
SOURCE: Remote code for Panasonic TV/VCR combo
Use the RCA universal control programing the code 109 in vcr funtion and will work..... i try and work....
SOURCE: Need operation manual for VCR Panasonic Model # PV-V4535S-K
here the service manualhttp://www.encompassimaging.com/shop/research_new/MSC/PVV4525S.pdf
and here operation manualhttps://panasonic.ca/PCS/OperatingInstructions/PVV4535SK-OI-Eng-Fr.pdf
SOURCE: need code for panasonic omnivision VHS (tv/VCR
11480 if you are using an XFINITY Motorolla Set Top Box with an XR2 remote and the TV model above
However, trying this one remaps the TV input button to Night mode.
11947
Then trying Setup until green lights flash, and entering 11250 somehow resets it.
