SOURCE: lost the bugaboo cameleon manual - need to install seat
You can find the user guides on the Bugaboo website.
https://www.bugaboo.com/US/en_US/support/product-information-strollers
SOURCE: The frame tilt seized on Bugaboo Cameleon
bUGABOO will send out free replacemnt buttons even if your pram is out of warranty you need to contact them. They will fix the problem but i had to put them in the oposite sides to what their instructions suggested for them to work so def a fiddly job but does fix problem.
SOURCE: Can I use the cameleon or frog seat frame on a gecko chasis?
HIYA.... IVE HAD ALOT OF BUGGIES AND PRAMS... IVE ALSO MADE MANY BUGABOOS UP, JUST BY USING USED PARTS AND PIECING THEM TOGETHER.
ALL COMPONENTS FROG, CAMELEON AND GECKO FIT ONTO 1 AND ANOTHER. YOU COULD BUY A FROG SEAT FABRIC TRY EBAY FOR THE CHEAPER OPTION, THIS IS EXACTLY THE SAME SIZE. THE CAMELEON 1 WOULD ALSO FIT, AS IVE HAD A CAMELEON COVER ON A FROG SEAT FRAME AND IT FITTED JUST AS GOOD :)
HOPE THIS HELPS X
SOURCE: Cameleon Jogger Stroller: The hinge on my bugaboo cameleon is stuck-in and n...
How to fix a Bugaboo Handle
If you are not a handyperson type, take these instructions
to you local Bicycle Mechanic or Small engineering shop.
The bugaboo handle fault is caused by two small plastic pins
shearing of a plastic disk that actuates two metal locking rods. Why bugaboo uses a plastic disk for
this critical component is beyond me!
1/.
Remove the domed star lock washer.
This is the hardest part of the job. Most people try to leaver this off in the hope of re
using. First problem with this is
you will mark or damage the surrounding plastic second is star locks are not
intended for reuse and will never hold as well as when first used, so best find
a new replacement. A hardware
store should be able to source some for you. Quickest way to remove a dome washer is to carefully cut a
slot in the dome with an angle grinder and then use a large screwdriver to
prize off.
Note it is best to open and repair one side at a time, so
your moving and flexing one side of the handle does not dislodge parts in the
other side.
2/. The lock
mechanism is very simple; a wire rod rotates a plastic disk. The disk has two plastic pins that move
the locking rods in and out of the inner hub into and out of the outer
hub. You need to ether repair the
disk by drilling out the pin stumps and finding a replacement metal screw you
can fit / glue in. Or (my
preferred choice) have a new metal disk fabricated that will last a lifetime.
3/. Reassemble
handle locking hub and check operation.
(I use a small amount of the grease used for taps to give a smooth
action) If all has well fit,
the new star dome on the hub shaft and tap home. To protect the dome finish I
use a large socket from my socket set and an old rubber washer from a toilet
cistern.
4/. Repeat
operation on the other side. Note
the disks are mirror images of each other and are not interchangeable. Bugaboo calls the side with the brake
lever “LEFT” the disk will have a
serial number that ends with “L”.
I have had metal disks laser cut and stainless steel pins fitted. Cost of a disk with a new star dome
washer is $75 New Zealand. If you
like one or a set, you can contact me [email protected]
Regards
Steve
SOURCE: will a frog seat frame fit on a cameleon chassis
Yes it will fit. the fabric seats are not interchangeable but everything else is. Currently I have Cam wheels on my frog chassis. As well as a cameleon canopy, and a fabric flease set on my frog seat.
