SOURCE: thermometer not reading correctly
I would guess the outside thermometer has lost its calibration.
Does it seem consistently 5, 10 or 20 degrees off all the time?
Let me know.
Regards,
SOURCE: My AcuRite 00992 wireless weather
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed.
SOURCE: I have an acurite atomic
I had one of these a while back and it had a required sequence for putting in the batteries. When the signal dies and you have to replace the transmitter batteries and the clock batteries in a certain sequence. The transmitter batteries cannot just be replaced. You also had to remove the clock batteries, then put in the transmitter batteries, then replace the clock batteries.
SOURCE: manual for acurite ik634160 weather station
http://www.acu-rite.com/product-manuals.html
http://www.ehow.com/way_5552159_acurite-atomic-clock-setting-instructions.html
Please find what you want at the above links....
