Tried unplugging it and plugging the wires back in to reset that didn't work seen that there might be a fuse to reset it and i seen unhook the battery over night not sure what to do please help
SOURCE: Transmission fluid change interval for Mercedes C230 Kompressor
hi, mercedes are good for 200,000 before you change transmission oil, hope this helps my E300 has done 350,000 and still changes fine as the oil is not a lubricant as such it lasts longer and does not lose it's viscosity, hope this helps you, thanks for useing fixya
SOURCE: can't open a 2002 Mercedes c230 kompressor sun roof
It's typically the motors or the special drive tubes that it uses. If you here a clicking noise then the sunroof became to tight and ruined the motor gears. You can actually switch the two motors, one is for the shades and needs less power then the other motor. They are identical, switch them. Nex make sure they are very tight to the 3 mounting bolts, there is a rubber washer bushing that wears out and alloys the motor to flex too much, causing the gear mis-alignment and gear grinding. This works great I do it all the time.
SOURCE: reset radio code C230
This happened to me too. I didn't have the code, and my service tech called the dealer and they gave it to him--we entered it, and I wrote it down in my glove box, and it worked immediately.
SOURCE: I have an engine fault code of p0170 on a mercedes
hi this is showing fuel trim bank 1 malfunction, this could be caused by the following things, intake leak, AIR system, fuel pressure/pump, injector/s EVAP canister purge valve, or HO2S ( air fuel mix incorrect) if it starts and runs fine, i do not think it will be fuel pump, or the injectors as this would make it run rough or even not start at all, if it was an intake leak, you would be suffering from high rev's when you start the car and would take a long time for the rev's to come down, so really, that just leaves the HO2S (sensor/s) these are located one on the exhaust manifold ( from engine follow exhaust manifold you will come to a things sticking out with some wires on) this is HO2S sensor bank 1, or if you look under the car on the exhaust, just past the catalytic converter you will see the same thing, this is HO2S sensor bank 2, it may be either of these, but i possibly would go for the first one, EVAP..it could be, if you have an air leak on it, the EVAP can be found under the hood/bonnet, at the front on the right hand side as you look into the engine/motor bay just in front of the screen was bottle...hope this helps
SOURCE: where is the low pressure
open engine hood its at the right front on the ac condenser it's covered by black plastic flap open the little flap you can see the low pressure valve in it.
