Replace the roller set for that draw and the associated clutch. Does this happen with the second draw also?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Panasonic DP 2500 J81-J82 paper jam
Check the sensor lever spring and cable on top of dual path guide (on top of fuser unit) also if the door stopper has been broken there is a good chance the door may be slightly deformed in which case a gentle adjustment may be reqd. check on the diverter solenoid there should be NO spring attached to the white guide. that is supposed to be removed when the adu option is fitted.
SOURCE: change papaer size and frequent papaer jams
OK it seems to be a problem with pick up clutch and vertical feed rollers ( When you open the left door and hinge in level of cass you will see axis with the tree little rollers- clean it with alcohol or water).Pick up clutch is better to replace it FK2-1068 (europe code).
Testimonial: "yes, you are smart. it was the clutch"
SOURCE: Ricoh Aficio 2022 jams duplexing only
You can't get that unit as one whole part, you would have to order each part separately. Also, if the paper is warped or curling, replacing that interchange unit won't change anything.
Try fanning the paper and flipping it over, or use a new **** of paper and see if that makes a difference.
SOURCE: My canon pixma MP470 printer
Hi
Please inspect again for paper jam located inro the paper tray, in the ink cartridge compartment and rear door of the printer (back door of the printer). If you find the paper jammed, it solves you problem and try to print again.
If not, just open the cartridge door, turn off the printer and move the cartridge using your hand the ink cartridge to the left going to the right and then right to left for 2 times. Then try to print again, also jammed message errror is related to stuck up cartridge.
