How can I disable the system low battery beep until I can get a new battery? This is a Simon3 security system.
SOURCE: System Low Battery
Response 1 is correct. If you plugged the transformer into an outlet before connecting the battery the system wont see the battery and give you that error. Should be a simple fix however. Unplug the battery and then the transformer, then reverse the process. Plug in the battery and your Simon should power up, then plug in the transformer. If this doesn't help then you should replace the battery. Did you buy the system from a dealer and have it professionally installed or did you do-it-yourself? If it was professionally installed have your technician come back out to diagnose/replace the battery if needed. Good Luck.
SOURCE: system Low Battery Alarm
You can silence trouble beeps by arming and disarming the system or by pressing status button; however, trouble beeps resume after 4 hours if the trouble condition as not been fixed. You can turn the trouble beeps off in the programming option 40. This should be done by your security professional because any mistake you could change other parameters in the system and the system may not work correctly. Hope this helps
SOURCE: Simon 3 "System Low Battery" after 3 years use
I install these panels. For the low battery message to clear you need to power the system down completely. To do this you need to unplug the battery and also unplug the transformer plugged into an electrical outlet. When you power the system back up, you need to first plug in the battery leads. Then the transformer.
SOURCE: system keeps beeping that sensor 3 is low battery
Did you try a system reset? You should be able to bypass.
SOURCE: battery low sensor failure on Wireless Simon ADT
the sensor seems to be malifunctioning and will have to be replaced
