Car Audio & Video Logo
Where to buy a wiring harness for a power acoustik radio ptid-8310nrb?
Installing a ptid-8960 power acoustik into my new 2011 mazda 3 what wires should connect or can i even install it without getting the wire harness adapter to make it like the same connections not quite...
You absolutely should use a wire harness for this installation. Not using one would require you to clip the wires to factory radio connector, making re-installation of the factory stereo nearly impossible. Even worse, you would have to wire the connector that came with your PTID-8960 deck to the clipped ends. This task would be nearly impossible, as the factory wiring is too short to extend out of the dashboard where you can work with it easily.
Save yourself the trouble.
I tried finding the exact item you will need, but it seems the Mazda 3 comes with stereo options that could affect which wire harness you'd require.
Here is a link to Crutchfield: http://www.crutchfield.com/p_120707904/Mazda-Receiver-Wire-Harness.html?tp=2977&tab=other_items
You can use their site to select your car and installed options, and they will return products compatible with your vehicle.
Missing wire 4 from manual....whats the name of wire
just had the same problem-it does not come with the stereo or even the DTV1 box, it only comes with the NAV1 unit. Luckily I found a local stereo shop that sold me one out of ther NAV1 box since I only bought the DTV1 box with the stereo and I needed it. So hopefully you will have teh same luck , either that or you will have to buy it directly from Power Acoustik.
2answers
Power Acoustik PTID-4007 Okay, so I checked my radio fuse, it's fine. Checked for constant and acc 12v. and they are there. fuses on harness are good. I spliced my adapter harness onto the PTID-4007...
i have Power Acoustik PTID-4007 my problem is not turn on lcd not out audio but yes is take cd and out cd, the screen is move in three postion. help me please
thanks
2helpful
Help i need a wire harness for power Acoustic dvd player
you would have to order it from poweracoustik.com. go to poweracoustik.com then go to contact and there will be a number call it an order.
2answers
Power Acoustik PTID4003 AM/FM/MP3/DVD w/3.6 TFT PTID-4003
he has to buy a mounting kit and wiring harnest for your car so it will fit in right. when he buys that there will be instructions that come with it. i hope this helps
Top Power Acoustik Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
