The mechanism operates easily manually with the door open or closed but it feels a little loose even after I made sure all the screws are tight.
SOURCE: Powerbolt 1000 started beeping and quit functioning
To provide a further bit of information. According to tech support the beeping can be caused by EITHER a bad keypad (about $15) or a bad circuit board (about $80, so, time for a new lock). The easiest way to tell is to:
After powering back up, if the unit keeps beeping, the circuit board is bad. But if it doesn't the keypad is bad. You can order the replacement keypads from Weiser via the 800 number listed in the previous comment.
SOURCE: powerbolt does not lock, motor operates but
your may just need a new battery. im not familiar with that model but the one i had would blink the lights when the batt was low.
SOURCE: Weiser keypad deadbolt lock deadbolt does not move
Hi... You have too be sure that the deadbolt is free when it go inside the deadbolt hole... however this system is very low power and the (over torque clutch) will sleep if the deadbolt it's not completely free.
Also if you try to open the door before you unlock it, you may block the the deadbolt inside the deadbolt hole. Take care too unlock the door before open-it...
SOURCE: bolt not moving while plastic gear spins. When I
It sounds like you have a mechanical bind going on. If you cannot correct it and feel that you have a defect within the lock, contact Weiser Lock-mechanical defects are lifetime-warrantied.
Here is a link to their Support Contact page:
http://www.weiserlock.com/CustomerService/ProductSupport/SupportContact.aspx
SOURCE: My Powerbolt 1000 only works
Follow this link to find out how to remove the cover for your Powerbolt:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
This link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
A note about the PDF files: If you cannot view a given file, you need to
first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
