There are hundreds of internet recipes for pork shoulder (or porkbutt--which is just a couple pieces of pork shoulder that are butted together and tied with string).
THIS COULD BE SEVERAL THINGS,IF YOU SEE THE IGNITOR ON FOR SOME TIME AND THERE IS NO FIRE THE IGNITOR IS POSSABLY THE WEAK LINK.IF THE OVEN TEMP IS LOW AND IT SHUTS OFF (THE IGNITOR) YOU MAY HAVE A BAD SENSOR OR MAIN PCB. IF THE TEMPERATURE IS OFF BY WITHIN 35 DEGRIES YOU CAN ADJUST IT (CHECK YOUR BOOK)
Step 2
Remove turkey from its wrapping and remove neck and giblets from inside the cavity. Set aside to make gravy later (see Related eHows).
Step 3
Rinse turkey inside and out with cold water. Pat dry with paper towels.
Step 4
Put oven rack on lowest level of oven.
Step 5
Place turkey, breast side up, on a roasting rack in a roasting pan.
Step 6
Rub the outside of the turkey with olive oil.
Step 7
Salt and pepper the turkey's body and cavity.
Step 8
Roast turkey about 3 hours, or until a meat thermometer inserted in the thickest part of the thigh registers 175 to 180 degrees F.
jQuery('.article ol .image').each(function(i,e){
var $this = jQuery(this);
$this.find('img').error(function(){
jQuery(this).remove();
$this.remove();
Tips & Warnings
In general, a turkey should be roasted 10 to 12 minutes per pound if it is not stuffed and 12 to 15 minutes per pound if it is stuffed.
In general, you shouldn't cover a roasting turkey (or any roasting meat); you want the skin to get a nice, deep brown all over, and you don't want it to steam in its own juices. However, if the turkey begins to brown too quickly, well before it's likely to be done, you can cover the brown parts loosely with aluminum foil. (This is likely to happen with larger birds.) Try to cover as little of the turkey as possible so you don't create steam.
Be sure to check out other eHow turkey recipes - search the site for "turkey."
Who Can Help Sponsored
How to Lose 30+lbs Guaranteed. Try it Free.
hope this helps u
please rate me..........................
thank u for using fixya
regards
sivaranjini
Set the oven thermostat to 100 degrees ( very low heat) and wait to see if the onen indicator goes off. If it doesn't then the oven thermostat may be faulty. If you have an oven thermometer, then use that to check the oven temperature.
