HP LaserJet P2055d Printer Logo
w
wonex Posted on Nov 20, 2016
HP Laserjet P2055d "jam in out put bin" problem
3 Related Answers
Anonymous
  • 38 Answers
  • Posted on Jun 16, 2010
SOURCE: Paper Jam at HP LaserJet P2055d
There is output sensor where the papers come out, make sure its lowered down, be VERY CAREFUL not to break it.
Anonymous
  • 1751 Answers
  • Posted on Nov 23, 2010
SOURCE: i AM USING HP laserjet P2055d printer and its
Hi
the last sensor on your printer it is stuck
check fro paper on it or if it is broken
Pls vote me to keep me alive
BaronVonNuke
Mark Schmit
  • 1915 Answers
  • Posted on Mar 18, 2011
SOURCE: when hp laserjet p2055d printer
This happens, usually when a user is not carefull about removing paper from the exit bin. Normally what I find is that the flag that detects paper exits is stuck. There should be a small set of fingers that pop up as the paper exits. If the do not move up and down smoothly then this is where your problem is. Most times if you wiggles them around and push down they should reingage properly.
2answers
Jam in cartridge area
Hi, remove the toner cartridge out of the printer then remove the jammed paper.
1helpful
REMOVE ALL PAPER FROM BIN ,OUT PUT BIN IS FULL Hi
Does not sound like a paper jam problem but a sensor problem sensor acurator is broken or out of place or the sensor is bad worse case the control that the sensors reports to is bad. Check you Output Bin Sensor acurator.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How can print power point slide in hp laserjet P2055d?
why i can't print power point slide in laserjet P2055d?
4helpful
When hp laserjet p2055d printer says remove paper from bin
1helpful
When i issue a print command it wouldn't print but state that the out put bin is full what are the possible solutions
The sensor that monitors the output bin is broke, jammed or missing.
At the top of the printer where the paper exits and lays flat. There should be a plastic rod that goes from one side to the other.
It has rollers on it to pull the paper out. There should also be a black plastic flag that goes up and down as paper comes out of the printer. Use a flash light if you have to. Move the flag with your finger up and down. It should almost float. If it is stuck in the up position it causes the printer to think that the output bin is filled up with paper. If it is stuck push it down gently. Make sure that it lifts and that gravity pushes it down.
3helpful
I AM USING HP laserjet P2055d printer and its giving me an error saying "jam in output bin" What should i do because I cant see any jammed paper?
Hi
10helpful
2answers
k24674
Grand Canyon Tech
Grand Canyon Tech
