Hope this is of some help
the thermal fuse is blowing because the unit is getting to hot you replacing the thermal fuse has not cured the problem, and it will blow again , the problem is the thermostat is set to high or is faulty / allowing the unit to go over temperature hence the thermal fuse blowing
its the control stat that you should be looking at. good luck
Testimonial: "hi Bob, thank you for responding. I've been looking around online and can't seem to find anything on the control stat. Can you tell me where to find it? Is it being the on/off switch?"
Any help would be appreciated
HAVE A LOOK AT THIShttps://www.youtube.com/watch?v=jTFuVLEH...
MAY BE OF SOME HELP
