Question about Bunn Coffee Makers & Espresso Machines
Removing off & on warming switch from a velocity bunn 10 cup coffee brewer
SOURCE:
informatica
  • 1114 Answers
SOURCE: bunn pod coffee tea brewer
Visit the Bunn website on the following link: http://bunn.com/retail/service/faq.html You can download manuals, read the FAQ & get telephone support from them. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 25, 2007
  • 625 Answers
SOURCE: Coffee Brewer comes out warm not hot
look at the top of the coffee maker you'll see two screws and the warmer tray and the cover for adding water. remove the two screws and lift the top off. the warmer has two push on spade terminals. pull the wires off them. below is a tray where the water goes and you'll see a brass bushing. this is screwed into a fitting on the water tank. use a piece of steel as a spanner and unscrew this fitting. don't lose the gasket that's under it. the main wires for the burner element and thermostat are also under this tray. look at the top. there's nine screws that hold the top on the water tank. two white wires go to the tank warmer and two wires go to the tank heater inside. you can try turning up the thermostat setting to a higher range and see what happens. there's a copper pipe that comes from the tank to the sprayhead the tank holds approx three urn fulls of water. if you have an analog meter you can check the element for continuity on the RX1 range. Do the same with the tank warmer element. Bunn-o-matic has a web site you can buy replacement parts or nelson appliance can get you parts too.
Posted on Nov 19, 2007
  • 131 Answers
SOURCE: Bunn GRX-B 10 cup coffee brewer kicks breaker when we turn it on
If you just bought this brewer, ask your retailer if they will replace it. if not, you can get ahold of the bunn warranty department in your country. they will give you instructions on getting a replacement. This brewer has a dead short in it.
Posted on Feb 13, 2009
  • 40 Answers
SOURCE: Coffee grounds overflow out of basket into top of coffee pot.
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Posted on Jan 04, 2010
  • 28 Answers
SOURCE: Keurig B60
Check the needle inside the k-cup holder to ensure it is not clogged. You can completely remove the k-cup holder by pushing up from the bottom (where it dispenses into your coffee cup). Then rinse it out with hot water using your kitchen sink sprayer. The manufacturer also recommends inserting the tip of a small paper clip into the needle to push out any debris if needed. Then replace the k-cup holder by aligning the arrows and snapping it back into place. Next try to brew your regular cup of coffee and see if that fixed the problem. Hope that worked for you...Best of luck!
Posted on Feb 07, 2010
Our bunn NHS Velocity was unplugged accidently. Now when we make coffee it is really luke warm and the light doesn't appear on
This is really a home style VPR brewer (but looks nicer)
if you listen to their video (link below) they mention it has a pre-heated tank of water already in the brewer. This means the brewer needs to be pre-filled with a full pot of water and pre-heated prior to using the brewer. Unplugging this unit won't be a problem UNLESS it was emptied of tank water and not refilled when powered up.
* The unit will try and heat up the tank of water but if empty then just air which overheats the unit then blows the thermal fuse. Call for service.
* The warmer is still working but it's not hot enough to brew frequently as the warmer may take up to an hour to get the tank hot enough to brew or it may not get hot at all if it's own thermal fuse blew too.
* Final; call for service to be safe.
Aloha, ukboy57
https://www.amazon.com/BUNN-Velocity-10-Cup-Coffee-Brewer/dp/B00EAQJCWW/ref=sr_1_1?ie=UTF8&qid=1516431654&sr=8-1&keywords=bunn+nhs+velocity
Dec 30, 2016 | Bunn Coffee Makers & Espresso Machines
Replacement 10 cup glass coffee pot
  • Items found similar to "GEMCO 10 Cup Glass Replacement ... www.ebay.ca/sch/sis.html?_nkw=GEMCO 10 Cup Glass Replacement Coffee... Items found similar to "GEMCO 10 Cup Glass Replacement Coffee Maker Carafe Decanter"
  • Items found similar to "BUNN Black Coffee Pot Carafe 10 ... www.ebay.ca/sch/sis.html?_nkw=BUNN Black Coffee Pot Carafe 10 Cup... Please enter a minimum and/or maximum price before continuing. C $ Enter minimum price to C $ Enter maximum price ...
  • One All 10 Cup Glass Eurostyle Universal Replacement ... www.amazon.ca/Glass-Eurostyle-Universal-Replacement-Carafe/dp/...
    • 4.7/5
    • 7 REVIEWS
    • ONE-ALL
    One All 10 Cup Glass Eurostyle Universal Replacement Carafe, Black: Amazon.ca: Home & Kitchen ... This replacement pot fits perfectly with my Braun coffee maker, ...
  • Bunn 10 Cup Replacement Glass Coffee Maker ... - ebay.com www.ebay.com > ... > Coffee & Tea Makers > Replacement Parts & Accs
    • SELLER 100.0% POSITIVE
    • KNIGHTDALE, NORTH CAROLINA
    BUNN 10 Cup REPLACEMENT GLASS COFFEE MAKER CARAFE DECANTER POT Black in Home & Garden, Kitchen, Dining & Bar, Small Kitchen Appliances ' eBay
  • images of Replacement 10 cup glass coffee pot bing.com/images 7f4o0&w=143&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">c03o0&w=148&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">0e6o0&w=113&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">3c4o0&w=113&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2"> See more images of Replacement 10 cup glass coffee pot
  • MELITTA REPLACEMENT GLASS COFFEE POT CARAFE 10 CUP ... www.ebay.com/sch/sis.html?_nkw=MELITTA+REPLACEMENT+GLASS+COFFEE... Find best value and selection for your MELITTA REPLACEMENT GLASS COFFEE POT CARAFE 10 CUP MINT search on eBay. World's leading marketplace.
  • Replacement 10 cup glass coffee pot - Fixya www.fixya.com > Forum > Coffee Makers & Espresso... Replacement 10 cup glass coffee pot - Coffee Makers & Espresso question
  • REPLACEMENT-Coffee-Maker-GLASS-POT-Mr-Coffee-10-12-cup ... www.ebay.com/sch/sis.html?_nkw=REPLACEMENT-Coffee-Maker-GLASS-POT... Items found similar to "REPLACEMENT-Coffee-Maker-GLASS-POT-Mr-Coffee-10-12-cup-"
  • Amazon.com: Medelco 10 Cup Glass Eurostyle Universal ... www.amazon.com > ... > Coffee Machine Accessories > Coffeemaker Pots > Fits my Braun 10-cup coffee maker perfectly. ... Medelco Glass Eurostyle Universal Replacement Carafe - Black, 12 Cup 3.5 out of 5 stars 109. ...
  • Cuisinart® 12-Cup Replacement Carafe in Black ... www.bedbathandbeyond.ca/store/product/cuisinart-reg-12-cup...
    • $34.99
    ... > Cuisinart® 12-Cup Replacement Carafe in Black ... 12-Cup Programmable Coffee Maker in ... original glass coffee pot and the replacement pot fits ...
  • One All Universal 10-Cup Eurostyle Glass Replacement ... www.walmart.com > ... > Kitchen Appliances > Coffee & Espresso Makers
    • 4/5
    • 15 RATINGS
    • $7.84
    • IN STOCK
    Buy One All Universal 10-Cup Eurostyle Glass Replacement Carafe, Black at Walmart ... 10-Cup Eurostyle Glass Replacement Carafe, ... Cup Glass Coffee Replacement ...
  • Mar 10, 2016 | Coffee Makers & Espresso Machines
    Just bought a bunn and it sounds and feels hot on the tank but water not coming thru to make the coffee
    This is a common question for the BTX-B.
    It's a commercial brewer that needs to be pre-filled prior to turning on.. It also needs to be filled again with a full carafe for it to brew properly. I have a link below that will explain how to set up and use this brewer.
    Aloha, ukeboy57
    https://www.bing.com/videos/search?q=bunn+grx-b&&view=detail&mid=E6D1ADD550DA3DA5B120E6D1ADD550DA3DA5B120&&FORM=VDRVRV
    Feb 11, 2016 | Bunn 10 Cup Home Coffee Brewer
    How to fix a Bunn NHBX that produces warm, not hot, coffee?
    Thermal fuse is blown. Above and almost behind tank, and most likely brown. New one at www.bunn.com
    Mar 02, 2015 | Bunn NHBX-B Contemporary 10-Cup Home...
    How do I set up my new 10 cup Bunn velocity brewer to brew only 4 cups?
    To do that it is a good idea to put water for four cups and four coffee spoons of coffee. Kolbrun
    Oct 04, 2014 | Bunn NHB Coffee Maker
    How should I set the brewer up to brew only four cups?
    pour only 4 cups of water & adjust the amount of coffee to suit your taste
    Oct 04, 2014 | Bunn 10 Cup Home Coffee Brewer
    How do you clean the Bunn 10 cup classic comercial coffee maker it is a BX-B model?
    To clean your brewer, with the machine still turned on, pour in 1 qt of white vinegar and let it sit in your brewer for 2 hours. At the end of 2 hours, you will flush it out with 8-10 decanters of water.
    Dec 26, 2010 | Bunn 10 Cup Home Coffee Brewer
    I just purchased a new a10 bunn coffee maker and it just doesn't brew a hot pot of coffee. It is warm enough to drink without cooling it like my old bunns and the cup of coffee is almost cold before you...
    Plug in brewer and turn on vacation switch on side
    of brewer. Allow 15 minutes for water to heat to proper
    temperature. This is a quote from bunns troubleshooting page. Also it should be under warranty in which case you could go to www.bunn.com and call their service line and either have them send a tech to look at it or have you send it off for warranty repair. Hope this helps.
    www.midstatebeverage.com
    Nov 30, 2010 | Bunn BT10B Coffee Maker
    Bunn 10 cup home coffee maker
    It sounds like a seal/gasket is defective causing it to leak. Please locate the model and date code on the bottom of the brewer and contact customer service for troubleshooting and replacement options.
    Feb 05, 2010 | Bunn 10 Cup Home Coffee Brewer
    Jan 15, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
    Coffee Makers & Espresso Machines Logo
    35 people viewed this question
    Top Bunn Coffee Makers & Espresso Machines Experts
    Inky Fingers
    Inky Fingers
    gbob59
    Marvin
    Marvin
    Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
