KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
Posted on Jul 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kitchenaid microwave makes a loud noise and does not heat
Anonymous
Level 2:
Sergeant:
  • Expert 187 Answers
  • Posted on Jul 20, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
187
Questions
0
Helped
97059
Points
558
try these
  1. Check timer and clock settings
  2. Reseat the element
  3. Test the element
  4. Test the element connectors
  5. Test the oven temperature control
  6. Test the oven selector control
pls rate my suggestion..
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Loud noise when cooking
I had an arcing sound coming from above the cardboard panel inside the microwave. When I saw it sparking I took the cover off and saw that these two aluminum looking things had come loose. I removed the cover and did a fair bit of 'fine tuning' to get it working again.
My Kitchenaid combo convection/mw works on convect but has a loud humming and no heat on microwave.
A loud humming noise in microwave mode will usually be a shorted high voltage diode or bad magnetron.
KitchenAid KCMS1555RSS stopped heating. Everthing else works, full display works, time counts down, turntable rotates, light comes on, etc. but no heat. makes loud hum. Magnatron? Cost to replace? Unit is...
If it is making a loud noise, check the diode and magnetron for damage.
BEWARE OF LETHAL VOLTAGES!
The fault may be just the diode and a reasonable cost will be involved. If it is the magnetron, depending upon where you purchase one from will command the price.
Hope that helps.
Not heating and making a loud noise
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
llllllllllll'l
Runs normally, but makes loud hum. not heating. in defrost mode, loud hum, then normal sounds, then loud hum, then normal...
Basic Microwave Oven Troubleshooting Tips
heatman101
2helpful
Kitchenaid KHMS155LSS 1000 watt microwave makes grinding noise
Chances are you have a bad stirrer motor or the stirrer blade is jamming or loose on the motor shaft.
Your owner's manual should tell you how to remove the stirrer cover to check it.
If for some reason you don't have your owner's manual, you can download it free here, as well as the parts manual for your model.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
2helpful
Loud humming noise
If all of your door switches check out, replace the magnatron, capacitor, and diodes.
3helpful
Kitchenaid builtin microwave buzzing
I would recommend changing the diodes as well. This will usually take care of the problem.
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
