Check power plug at base is plugged in and turned on at power point ( this has happened twice in last two days on my phone base power pack - by others unplugging it)
Check line cord at base unit is plugged in too
base phone not working suggests no power on base and phones battery has gone flat .
If you have no dial tone the problem is most likely the base station has failed, nothing you can do will kill the dial tone (no button you pushed etc.) except a failed base station.
That indicates that the phone is not synced with the base station. Try putting it next to the base station and resetting. Here are some links that may help:
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Check the Battery on the Handset. remove the pwr frm the base unit n connect aft 30 sec. aft this if it still says the same msg, then the handset needs to be replaced.
It was easy for my Emerson Dect 6.0 to be switched either rotary / pulse by just pressing the "FLASH" button for 3 seconds until it beeped. Problem solved.
Or if that doesn't work, you have to:
Tone/Pulse You can switch the dial mode. In most situations the TONE option should be selected.
• Press the MENU button. Select BASE using <FLASH - or - CID> and press the MENU button again.
• Using <FLASH - or - CID> select DIAL MODE and press the MENU button.
• Using <FLASH - or - CID> select TONE or PULSE and press the MENU button.
OR
Press and HOLD the "<FLASH" button for approximately 3 seconds. T (Tone) or P (Pulse) appears in the display.
