Vehicle Parts & Accessories Logo
Mark Deboard Posted on Nov 18, 2016
My viper 4104 1-way remote doesn't work after replacing remote battery. 4th time it's happened, dealer just wants me to buy a new one every time, any solutions?
Wally
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Sep 30, 2019
Wally
Contributor
Level 1:
New Friend:
Answers
28
Questions
Helped
11623
Points
60
There is a very small connection pin under each button.
If they don't make contact information will not work on remote. You can check this by very carefully opening the remote. Don't open all the way just enough to see if the buttons are lined up. Take a flashlight and magnifying glass and look to see if they are all lined up when you push the remote. If they are not you will be able to see no contact. Take a toothpick and very gently Aline the pins.
If you touch them to hard they will break and your remote will be toast.
Walld"
5 Related Answers
Anonymous
  • 165 Answers
  • Posted on Mar 17, 2009
SOURCE: i have the viper 5900 installed in my 05 mustang.
replace the remote battery and reprogram the remote the problem on that kind of remotes is that the battery goes down quickly.
jason
  • 905 Answers
  • Posted on Apr 05, 2009
SOURCE: viper remote stopped working 791xv
I have the same remote and it comes disconnected in the battery section from the battery hitting it and then the commands and speaker stop working
as shown here
logosc75
Larry Spears
  • 625 Answers
  • Posted on Oct 03, 2010
SOURCE: my remote starter for my viper 5900 2 way trans
Try reprogramming the remote. Open the door, turn ignition on, press and release valet switch one time, then press and hold valet switch while pressing lock button on remote.You should hear a confirmation chirp from the alarm. Release both buttons.Turn off ignition. test.
Anonymous
  • 676 Answers
  • Posted on Feb 19, 2011
SOURCE: replaced truck battery and now remote doesnt work
Hello my name is Israel and I will be able to help you. First I will need for you to look for the alarm unit. The model you are giving me is for the remote not the alarm. Once you have this information, let me know and I will send you the instructions for programing the remote to the unit.
zohaibjaved1
zohaibjaved
  • 10 Answers
  • Posted on Dec 20, 2013
SOURCE: My viper remote is fully charged but doesn't disarm.
open
2answers
Viper Remote starter (Model 4115V1) does not immediately turn on...car will try to turn-over does not and about 45 seconds later, engines turns over. Viper was installed at Best Buy (authorized dealer
It sounds like a problem in the remote start module that was installed. I assume it has not always done this. See what type of warrenty you have on it. Probably none but sometimes suprises happen.
How do I program my keyfob to lock/unlock doors
take it back to the installers as they will have the unit necessary for the programming. It should not cost any thing as it should be part of the installation process.
My Viper remote won't turn on or charge.
The battery is probably dead. There is a guy on ebay that is replacing them. He fixed mine and it works great. The batteries dont last forever and you cannot just buy them they are a special type, also viper suggests you buy a new remote for $299 because they do not replace the batteries... how convenient. Hopefully that helps.
2answers
Viper fob unpairs after car battery removal. Antenna indicator LED never lights up even when doing the re-pair procedure. wut?
The first problem is, you went to bestbuy. The second issue is the remote should not lose the pairing because the battery was removed. Your remote is probably defective.
I have a Viper 5101 system, and we replaced the battery in the remote. Only the remote start worked. Then Nothing worked. Went to Best Buy to buy another remote and the guy gave us directions to try to...
hello
u will find a lot of wiring diagrams, codes etc and circuit diagrams help books and stuff like this at online places.. like reliable-store
for free
the girl in the chat box can help u instantly... im a frequent buyer there since Im a mechanic so take help from there
I just bought a used vehicle that has a viper system installed however the battery on the remote was dead and when i replaced it, nothing works? how can i locate the system its a 2001 ford explorer sport...
I have a solution, since this keeps happening to me. Go to Bestbuy, buy a 2 way remote for the 5701, they're $55. return the old one. The new one should work after you program it. follow the directions on the back of the box.
3helpful
4answers
My Viper 791xv remote isn't receiving the page information from the unit in the car. When I press the unlock, lock, or remote start button, it works, but then the remote beeps as if it didn't work (3 sets...
My battery ran low and I jump started my car which some how caused the problem. My viper technician made me a buy new remote but the problem continued even with the new remote.
Try disconnecting the battery of your car for ten minutes and then reconnecting it. It worked for me. Now i have a extra remote which i don't need.
2helpful
2answers
Viper remote starter-
we have a viper 600hf and it has recently started draining thebattery and it won't stay charged.
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
ZJ Limited
ZJ Limited
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
