Radio Communications Logo
F
Frederick W Gruetzman Posted on Nov 17, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to wire a Ranger SRA-198 4-Pin mike to a Ranger 3500 4 pin Radio
Mike Charette
Level 3:
Genius:
  • Ranger Master 1,847 Answers
  • Posted on Oct 03, 2018
Mike Charette
Ranger Master
Level 3:
Genius:
Answers
1847
Questions
Helped
490589
Points
2212
Check out the schematic first .It may be the same wiring .
5 Related Answers
Anonymous
  • Posted on Mar 31, 2008
SOURCE: I need the wiring diagram for A silver Eagle mike to a Ranger 2950 DX
1 shield & blue
2 white
3 red
4 black
5 n c
6 n c
yellow.. n c
Mechanic688
Mechanic688
  • 204 Answers
  • Posted on Nov 05, 2008
SOURCE: Omegaforce s45 mic wiring
Sadelta
1-Shield - Ground
2-White - Audio
3-Brown - Transmit
4-Green - Receive
Does this color code look like what you have in your mic?? sorry for the delay,,, Mechanic
Anonymous
  • 170 Answers
  • Posted on Dec 28, 2008
SOURCE: Diesel #8-32 echo power mics
cobra 4 pin is pin1= shield, pin2= mic audio (usually the shield is wrapped around the mic audio wire).pin 3= transmit or push to talk usually red or white whichever isnt wrapped with the shield, and pin4 = receive or speaker complete
5 pin cobra=1-Audio 2- Shield 3-Receive 4-Switching Wire 5-Transmit, you can jump pins 4 and two
Anonymous
  • 24 Answers
  • Posted on Jul 14, 2009
SOURCE: mic wiring diagram 4-pin
try http://www.cbtricks.com/
they have mic wireing diagrams
Anonymous
  • Posted on Aug 17, 2009
SOURCE: i have a turner plus 3 mic with 4 wires red,black,
i need to wire a turner +3 to my old midland 13-880b with a straight stereo plug(pusin)help
I have a 6 wire D104 . How do I wire it to a Ranger 2985 dx ?
Wiring a 6-wire D104 microphone to a Ranger 2985 DX requires connecting the wires in the correct order and configuration.
The Ranger 2985 DX has an 8-pin modular plug, and the D104 microphone has a 6-pin modular plug.
Here's one way to wire the D104 microphone to the Ranger 2985 DX:
  1. Connect the red wire from the D104 to the 8-pin modular plug's pin 4 (PTT - Push-To-Talk).
  2. Connect the black wire from the D104 to the 8-pin modular plug's pin 5 (Ground).
  3. Connect the white wire from the D104 to the 8-pin modular plug's pin 6 (MIC + Audio).
  4. Connect the blue wire from the D104 to the 8-pin modular plug's pin 7 (Receive Audio)
  5. Connect the green wire from the D104 to the 8-pin modular plug pin 8 (Transmit Audio)
  6. Connect the yellow wire from the D104 to the 8-pin modular plug's pin 3 (UP-Down).
It's important to double-check the wiring configuration with the user manual of the Ranger 2985 DX and the D104 microphone. Some manufacturers have different wiring configurations and it's important to match the wiring accordingly to avoid any damage to the device.
It's also worth noting that if you are not comfortable with the wiring process, it's best to consult with a professional technician or a radio expert.
How to wire a ranger sra 198 mic to a galaxy 4 pin radio.
if they are both 4 pins you shouldn't have to rewire it .
Galaxy echo 5 pin desk mike wiring to cobra 2000?
before you go thru all the trouble of wireing it ,what kind of radio did the desk mic come from.If it came from a galaxy then you shouldn't have to change a thing. 5 pin to 5 pin try it then if you have to wire it.
How to wire a mic
This might help as I don't have a color code for the mic. Radio pin code; 1 - Audio -2 - Shield - 3 - Receive - 4 - Sw. Wire -
5 - Transmit
MIKE WIRING GUIDE
Found this by Google searching;
5 Pin Mic Plug Model
Pin #1 Audio Output / White
Pin #2 Shield
Pin #3 Receive / Black
Pin #4 Common / Yellow
Pin #5 Transmit / Red
Wire a ranger sra-198 4 pin to uniden 5 pin
4 wire mics can't be wired to 5 pin unidens without extremely modifying the mic and replacing the mic cord
I have a cobra 148gtl with 5 pin side plug for mic.Im trying to wire a superstar dm 1000 echo mic to it,red,yellow,blue,white,& unsheilded wires dont know were they go.???????
ALLways start with ground. Find ground on radio pin with ohm meter. EVERY thing operates off ground. Once you find ground on radio....solder your ground wire on mike cord to corresponding # on mike jack. Once you have ground on proper pin then all else is elementary......use ohm meter to see which wires are TX and RX on mike.....last wire is audio wire.
20helpful
9answers
Mic wiring diagram
Want to wire cobra mic to a uniden washington radio
Top Ranger Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
