SOURCE: Norstar Phone System - How do I change the time?
press feature **time
enter the time.
Press Feature **date
enter the date
SOURCE: nORSTAR m7310
To Log Into System Programming:
Press FEATURE * * 2 6 6 3 4 4
Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Using the navigation keys, as displayed below, follow the next simple steps:
Press: NEXT Display will read: "B. General Admin"
Press: SHOW Display will read: "1. Sys speed dial"
Press: NEXT Display will read: "2. Names"
Press the SHOW Display will read: "Set names"
Press: SHOW Display will read: "Show set:__"
Enter the extension number of which you wish to change the name Display will read: "<##:name>"
Press the CHANGE softkey
Using the dial pad spell out the name Ex: If you need the letter
K press the 5 key twice and then press # to confirm the letter.
Continue until the entire first name is spelled. (note: you are limited
to 7 characters)
Press: NEXT (if you fail to do this step, the name will not be saved!!!)
Press the RLS key
Hope this helps!
SOURCE: can't dial out
On my 9417cw this happened from time to time and I found a very simple solution. Disconnect the power supply for a few seconds and plug it back in....voila!
SOURCE: Norstar phones compatible with NEC phone system
This is simple.
The answer is no.
Each company uses its own voice encoding and technologies...
Nortel will only work on Nortel phone system.
Cheers
SOURCE: We have the Northern Telecom (Norstar) compact DR5
enterd wrong password on vm too many times and was locked out
how do I reset it?
