If your Blyss doorbell won't stop ringing, there are a few steps you can try to troubleshoot the problem. Here are some possible solutions:
Check the wiring: The first thing to check is the wiring of your doorbell system. Make sure that all the wires are securely connected and that there are no loose or damaged wires. You can also try disconnecting the wires and then reconnecting them to see if that fixes the problem.
Check the chime: If the wiring is fine, the next thing to check is the chime. Make sure that the chime is properly installed and that it is not damaged or loose. You can also try removing the chime and then reinstalling it to see if that fixes the problem.
Check the bell push: If the chime is working properly, the next thing to check is the bell push. Make sure that the bell push is securely installed and that it is not damaged or loose. You can also try cleaning the terminals on the bell push to remove any dirt or debris that may be preventing it from working properly.
Check the transformer: If the bell push is working properly, the next thing to check is the transformer. The transformer is a device that supplies power to your doorbell system, and if it is not working properly, it can cause your doorbell to ring continuously. Make sure that the transformer is securely installed and that it is not damaged or loose. You can also try disconnecting the transformer and then reconnecting it to see if that fixes the problem.
If none of these steps help, you may need to contact Blyss customer support for further assistance. They will be able to provide more specific troubleshooting steps based on your particular doorbell model and setup.
- remove all the batteries from the bell
- ensure the battery in the doorbell unit is working and remove the back cover
- replace the batteries in the bell unit
- within 30 seconds of the bell unit sounding the bell, press the melody changer button on the back of the door bell unit once
Pair the Unit
- wait at least a minute after reset
- within 30 seconds of the bell unit sounding the bell, press the door bell button
I couldn't find the manual instructions for your Blyss MP3 wireless door bell... I asked your question on the UK Amazon store that sells that unit, but who knows when or if anyone will answer it Blyss Wirefree battery door bell with additional plug in bell
Besides that, you have listed this question in the wrong category. The below linked section may have others that are more qualified that might be able to answer your question who are more familiar with your product: Questions Answers for pair blyss wireless doorbell
>> If this was helpful in any way, please let me know so that I will continue helping others, by Clicking on the Helpful button below. Thank you :)
There are only picture instructions but from what it implies...
Reset the Unit
- remove all the batteries from the bell - ensure the battery in the doorbell unit is working and remove the back cover - replace the batteries in the bell unit - within 30 seconds of the bell unit sounding the bell, press the melody changer button on the back of the door bell unit once - remove all the batteries from the bell
Pair the Unit
- wait at least a minute after reset - remove all the batteries from the bell - replace the batteries in the bell unit - within 30 seconds of the bell unit sounding the bell, press the door bell button
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
