I try to del a file. Open in Windows 7/Word. Recd prompt File is Open in Microsoft Word" "Close File & Try Again" I noticed at the top "Read-only." How can I delete the file? I would appreciate it very much. Thanks in advance
Insert your USB drive in the appropriate USB slot in your computer.
If the Autoplay dialog box appears, select "Take No Action" and click the "OK" button.
Launch your anti-virus program, such as AVG Antivirus or Anti Malware.
Select the USB drive for the program to scan.
Click the "Start Scan" button or option.
Open the scan history for the USB drive when the scan is complete to see a list of viruses and warnings identified by the antivirus software.
If desired, select the options to "Heal All Infected Files" or "Move the Infected Files to the Virus Vault" to ensure these files are quarantined from your system.
Highlight each infected file in the scan history. Write down the file name of each infected file identified on the USB drive. Minimize the application's window.
Select "Run" from the Windows "Start" menu. In the Run window, type "e:/" at the command prompt to switch to your USB drive (or type the drive letter for your USB drive). Press the Enter key.
Type "attrib -s -h -r -a *.*" at the command prompt to remove the system, hidden, read-only and archive file attributes.
Type "del ####.+++" where "####" is the file name of the infected file and "+++" is the file extension, at the command prompt line.
For example, "del terriblevirus.exe" will specifically delete the Terrible Virus executable file. Repeat for each infected file on your list identified in Step 4.
Close the command prompt window; that is, exit the Run utility.
Maximize the window for your anti-virus program (which is still open) and repeat Steps 2 to 7 until no virus is detected on your USB drive.
Exit the anti-virus application.
or Click start click on my computer you should see your usb drive right click then select format.
another way is to control panel administrative tools computer management disk management right Click on your drive select format
Hope this helps
Hope this helps
http://ct.download.com/clicks?t=1141982088-ce770fd4fbc57664a08aea1a8f03b80d-bf&brand=DOWNLOAD&s=5
avg free 2012
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
