I have a Maytag M7DH65B2A. I hooked up a hose to the drain and routed the hose into a pipe. Now there is water coming from a small hole on the right side of the unit, dripping into the water container. The new hose is not clogged, Im not sure what the problem is
Had the same problem. Make sure you tighten the house a little with pliers. Also, make sure the dehumidifier is up a lot higher than where you're draining it into. Mine drains into a utility sink. But I have the dehumidifier propped up onto a dresser. I cut a small piece of hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
