My National Geographic Weather Station is the opposite. The outside sensor only indicates the temperature, but the single CR2023 battery lasts a year. The inside unit on my desk lasts around 5 - 6 months and lets me know if needs a battery by showing the outside temperature as ' -- '
Although the manual says 'rechargeable batteries are not recommended', I would try 4 Sanyo Eneloop batteries. Or you could contact Acurite Support and ask them if your battery use is excessive?
The indoor temperature and humidity and outdoor temperature readings can be calibrated on the display to improve accuracy. Calibration can improve accuracy when sensor placement or environmental factors impact your data accuracy. 1. To access calibration mode, press AND HOLD the "?", "?", and "SET" buttons for at least 5 seconds. 2. Once in calibration mode, the preference you are currently setting will be highlighted on the display. 3. Press the "?" or "?" buttons to calibrate the data value higher or lower from the actual reading. 4. Press the "SET" button to confirm the calibration adjustment. The " " icon will remain illuminated next to calibrated values. 5. The next adjustable data will begin flashing, indicating it is ready to be calibrated. Repeat Steps 1 - 4 to calibrate additional data. The preference set order is as follows: OUTDOOR TEMPERATURE INDOOR TEMPERATURE INDOOR HUMIDITY BAROMETRIC PRESSURE (must be set to MANUAL mode; see page 12) After 20 seconds of inactivity, the display will save the adjustments and exit calibration mode. Note: Calibrations will be erased if the display is reset or if batteries are removed and the power adapter is unplugged.
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
We would recommend a reset of your Weather Station. Please verify that you are using a good-quality, standard alkaline battery, and follow the steps below.
Remove the batteries from the outdoor sensor only.
In the outdoor section on the main unit, there will be a "CH" and number 1-3.
If on CH 1, press and hold the channel button on the back of the unit for 5 seconds.
Press and release the channel button one time, it should show CH 2. • If it does not change to CH 2, repeat steps 4 and 5.
Press and hold the channel button for 5 seconds.
Press and release the channel button one time, it should show CH 3. • If it does not change to CH 3, repeat steps 6 and 7.
Press and release the channel button one time, it should return to CH 1. • If it does not change to CH 1, repeat steps 8 and 9. ***Regardless of what channel you begin on, clear out each channel by holding the channel button and return to CH 1***
Reinstall batteries in the outdoor sensor.
Press and release the TX button.
Leave both units side by side for up to 30 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or [email protected].
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
I assume r-22 refrigerant by the pressure... you have a saturate temperature of approximately 41 degree and 71 degrees at the service port this equates to a 30 degree superheat. a condenser saturation temperature of 105 degrees and since the liquid line temp at the service valve is not given only the enterin indoor coil on the liquid line a 96 degree temperature this would equate to a subcooling temperatureof about nine degrees. You have too high of a superheat reading. verify that the bulb for the txv is correctly positioned and insulated. if it is then you need to remove the bulb from the suction line, hold it in your hand to warm it up and see if the superheat changes. you could also have issues with your ductwork. If the supply temperture is around 50-55 degrees then the unit is doing all it can.. Check the txv and the ductwork as the subcooling indicates that the condenser side is doing it's job, but the superheat readings indicate that you are starving the evaporator..
