Tip & How-To about Samsung Ln32b360c5d
Won't Power On
I show how I fixed a Samsung LN32B360C5DXZA 32" LCD TV that wouldn't power on after it was plugged into an outlet that was wired wrong.
Samsung Ln32b360c5d Logo
Samsung Model LN32B360C5DXZA not receiving power.
Power converter board is probably blown.
Take it to a repair shop.
my 32 inch lcd tv green line in panel
Try unplugging as suggested. Also, try different inputs (HDMI, component, etc.) and different cables to be sure it's not some external item causing problems or just one input. Also plug it into an outlet on a different circuit in your house.
If everything you try still shows the lines, it's probably the screen itself and is too expensive to fix.
2answers
Samsung Model LN32B360C5DXZA TV will not power on. Dead.
Check and replace damaged component/s at its main power regulator board, or, replace the board as card basis. If you wish to get more details, check this link.http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Won't power on
Check your power outlet for any loose contacts and ensure there is power. Try connecting the TV to a different power outlet.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
