Question about Health & Beauty
My chair is blinking 4 times and I do not have a manual
  • Marvin
    Marvin Nov 15, 2016
    Hi Make and model of the chair is needed.
    Top Expert:
  • Health & Beauty Master
  • 29,187 Answers
If it is a Pride Jazzy or similar, the Diagnostic Flash Codes are in this PDF file.
PDF]INFINFB2048_Jazzy_Select_14_Troubleshooting ... - Pride Mobility www.pridemobility.com/download.php?f=troubleshooting/INFINFB2048_Jazzy...
  1. Cached
  2. Similar
basic troubleshooting instructions for the Jazzy Select 14/14XL power chairs. ... on my Jazzy Select 14/14XL seem to be "dead" (controller does not light up when .... What if the left red battery condition meter LED on the VR2 or VSI is flashing? chair is blinking 4 times Google Search
Posted on Nov 15, 2016
6ya staff
SOURCE:
What does it mean on 1122 jazzy when the two red lights blink
JAZZY 1122 - Pride Mobility Products
www.pridemobility.com/...manuals/...jazzy/.../au_jazzy_1...
Pride MobilityJAZZY 1122. How a Power Chair Should ... NOTE: This owner's manual is compiled from the latest specifications and product information available at the time of .
Jul 31, 2015 | Pride Mobility Jazzy 1122 Electric...
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Not sure witch jazzy chair i got but the joy stick blink and keeps blinking i have tried pushing horn button twice and also turning it on and pushing joy stick forward waiting for it to beep but no beep....
The jazzy probably has a VSI controller and if it is sleep mode then the lights will scroll rather than blink. Now turn on the chair and see if the blinks have a pause between them, ie 4 blinks pause 4 blinks pause etc If they do count the number of blinks and this will give you the error code ie 4 blinks right motor 3 blinks left motor your owners manual should have a chart listing the error codes If not you can contact Pride tech support @ 1-800-800-8586 ask for jazzy tech support
Hope this helps
Feb 17, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Quickie s-525 joystick lights blink chair does not drive. what is the problem and its solution.
I need to know how many blinks you are getting ie 4 blinks pause 4 blinks pause etc. If you can count the number of blinks between pauses then we can figure out what the error is. Hope this helps
Feb 15, 2011 | Quickie Wheelchairs Auto Sunrise Med...
My pronto m91 was flashing 5 times on the yellow led and after i resert it like you said it ran for a minuet and now it flashes 4 times on the bottom yellow led.
I am new to this request. Hope you have had your chair fixed by now, but in case not. If you still need help I really need more chair information. What joystick? Many different joysticks with different yellow lights. With a 4 or 5 blink it could be a motor or battery voltage problem.
Jan 11, 2011 | Invacare Health & Beauty
All lights blinking rapidly
The number of blinking lights indicate the problem. Visit this site to determine the cause:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try pushing the manual brake release levers all the way to the floor (with the power chair turned off) then back up until they pop into place then turn the power chair back on. If you continue to have a problem, contact Hoveround, they are good at trouble shooting over the phone.
Oct 14, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Merits DL 52 i electric wheel chair, all leds flash 3 times as a error code. Battery is fully charged, then turn on wheelchair. All led are on. then when the joy stick is pushed, all leds flash 3 times...
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Jul 15, 2010 | Health & Beauty
Yellow lights blink and chair does not move on Jet 3 power chair
Jun 15, 2010 | Jet 3 Ultra Power Chair
Chair no longer charges, no flashing or blinking, lights,
May 07, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Power chair lights
where can i purchase lights to put on an invacare power chair
Oct 18, 2008 | Jet 3 Ultra Power Chair
Health & Beauty Logo
507 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
